- May 7, 2011
- Cook->Kent
EDIT....Sorry to those that have seen this thread before I was finished...too many things going on and hit enter on the wrong kb before I was finished. Then, naturally, as I edited this post, it logged me out so I lost the edit...figures....
I'll apologize in advance for the lack of pics as I'm quite literally just starting off this particular project, but rest assured, there will be plenty as the weeks and/or months progress.
Not that I want to sound like everyone else here in how their respective threads start off (no offense, of course) but, like many, I've been building my PCs for a good 10 years now. Granted, not as many as some, but long enough to know that most of the things I've done in the past could be considered a large waste...well...I could have spent $ on other/better things.
The overall goal here is twofold:
1) Quiet the system down considerably. I've recently moved to London and where the system is sitting, it makes quite a bit of noise that reverberates throughout the flat.
2) Where the system is sitting, it does get quite warm as I'm on the top flat, and the thing is sitting in a little loft even higher up. So, heat gets stuck up here very easily.
Bit messy...but the left opens up to the rest of the flat and it's annoying.
That being said, the setup I'm currently running isn't changing, rather the home in which it lives.
As you can see, it's a disaster in there. Additionally, the case and my plans are not going to cooperate so, in addition to the LC move, I'm also going to a MM Ascension.
And we'll say point #3 is good OC'ing ability.
I'm not as techy as some here with CAD and the like, so instead of posting up some nice renderings of what the case will look like, I'll just throw it up as some words...
The case itself will be configured as:
Front: Trinity
Rear: Horizon flipped 180
Top: Diamond
Left: Triple big window (fans up)
Right: Solid or triple big window
It will be somewhat stealthy in that all main components will be annodized black and the windows either clear or smoked.
Those components as shown above are:
Asus R3E
i7-970
2x Gigabyte GTX460s OC'd
8800GT for PhysX
12GB Corsair Dominator GT 7-8-7-20 @ 1866
Areca 1880-i
4x WD Raptor 740GDs in RAID0
4x 1TB Samsung F3s in RAID10
Blu-Ray RW
Needless to say, I need some room, in particular for the eight drives.
I haven't decided on the exact components for LC'ing, nor have I determined exactly how I'm going to do the loop or loops, but here's where I am so far.
Some D5 pump(s)
EX Supreme HF
Koolance GPU-220s
Koolance MB-ASR3E
3x TC PA120.3
I'll have one rad on the front at the bottom, with fans in the middle for some air to the mobo and the drives in the third spot.
The other two rads will be up top on the left and rear. For the loop, I'm thinking CPU/NB, two top rads, GPU in parallel, front rad. But, I'm open to more efficient suggestions. I'm also somewhat concerned about how I have airflow. All fans will be at 1k or 1400RPM. The entire front will be intakes, the side and rear as well as top exhaust. I still think there will be some positive pressure given nine intake fans and only six exhaust of 120mm variants. The additional four 80mm up top may make some equilibrium, but we'll see.
And for the sake of argument whether this is all necessary, let's just say it's going to be OC'd a lot.
As far as the rest of the case...the Areca card is somewhat of a pain, but easy in that the headers for the drive status lights have a common ground (I believe). That will make wiring much easier.
My old card RAID card, an Adaptec 2405 had a nice 8-pin header which was easy to retrofit an 8-pin mobo header cable I had and create a front light panel. Well, as now I have eight drives, I need 16 lights...eight activity and eight error. So, that being said, I'll have a rather nice light show up front for all these drives. As I "only" have five free bays off the bat to work with, we'll see how I'll do the res and pump setup as I'm sure I'll need some fan controllers and whatnot. I haven't determined whether I want to use two bays for the HDD LEDs or not....either way, the whole thing will be as clean as possible.
So, in the coming week or so, I'll be ordering the case itself. Once in, I'll be able to better plan the cooling solution. I'm more visual so I'll need to see it in person before I can lock in the plan.
In the meantime, as mentioned, I'm all eyes on more efficient setups. This will be quite a build I'm going to do here...at least that's my intention. So I'm all for those chiming in with their experiences on this particular case.
Front: Trinity
Top: Diamond
Asus R3E
i7-970
8800GT for PhysX
Areca 1880-i
Blu-Ray RW
Some D5 pump(s)
EX Supreme HF
Koolance GPU-220s
Koolance MB-ASR3E
3x TC PA120.3
