First off....
DO NOT USE RUBBING ALCOHOL
Rubbing alcohol potentially has impurities that can be worse off for your electronics than straight water... (PURE water is non conductive...)
Second:
Submersion can destroy the electronics. This was discovered the hard way early in water cooling when direct-die blocks were popular. So, to clear up the issue, find and use 95%+
PURE ISOPROPYL Alcohol
ONLY.
Third:
The idea of using the Isopropyl alcohol is that it evaporates. However, because I have been unable to find Ethylene glycol's solubility in alachol, I'm going to have to say Play it safe. Use generous portions of Isopropyl alcohol sprayed into and around the socket and anywhere it might have leaked. By "generous" I mean enough that its all pouring down the board. This way it will wash off if it can't evaporate with the alcohol.
Also, instead of of just using a fan, I would recommend either caned air, or an air compressor(NO OIL!!!) that you have made sure is properly maintained(Have you drained yours lately??).
If you use the air compressor... Don't be stupid and use the full 120PSI, turn it down to 30-40.
PS: Don't forget
Under the chips. That is where most the alcohol will collect.
An alternative to rubbing alcohol would be to put the items in an enclosed environment with a dehumidifier and run it constantly for a day or two.
That would not clear off the impurities that would be left behind by the water. Chances are there are minute salts and other things that when exposed to air again would absorb moisture and possibly conduct more electricity.
