Transferring user profiles to another drive
Corona2172
Hi all. I'm not sure if this is the correct place to post this question, so please forgive me if not. Anyways, on to my question:
I recently customized and received a new gaming rig. I have a 60gb intel SSD as my primary drive and a 2 TB hdd for storing my games, etc. My intent when I ordered it was that I could have the OS on the SSD and not much else. However, I installed all of windows updates and the drivers for my hardware (such as a BLU RAY optical drive and my mouse and keyboard and Sound card) and quickly realized that, with only 9.48gb left on my SSD (when I got the PC there was only 15gb left on it) I would not have any room soon. So, I stopped installing hardward drivers, etc. Because I want to use my PC for gaming, I know the appdata folder and MY Documents folder is going to fill to the brim with games saves, etc... I have absolutely nothing on the 2tb hdd. Now to the actual question:
1. How do I move my entire users profile folder to the hdd? If not the entire user profile folder, then at least the user/username folder that contains the Appdata and MyDocuments, etc)?
2. Even though I haven't installed anything except AVG, drivers and windows updates, do I have to do a clean install of windows, etc?
Any help is appreciated, because i've got this rig that I really want to try out, but I don't want to put any games on it yet until I can figure out how to do this....... I have looked at a few websites that attempt to show how it is done, but since i'm not that computer literate, I don't understand most of it, and it seems that each one has a different "BEST" method. The only website that looked remotely approachable was this one: http://www.sevenforums.com/tutorials/87555-user-profile-change-default-location.html . Even then, I didn't know which method (1 or 2) was correct for my situation, or if I should do a clean install first, even though there is virtually nothing on my PC as of yet.
Any and all help would be greatly appreciated.
P.S. I don't know if this is necessary, but I am including my dxdiag just in case.
Code:
System Information
Time of this report: 9/29/2012, 15:51:54
       Machine name: JOSEPHNOBLE-PC
   Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
           Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
       System Model: To be filled by O.E.M.
               BIOS: BIOS Date: 03/05/12 17:31:09 Ver: 04.06.04
          Processor: Intel(R) Core(TM) i7-3960X CPU @ 3.30GHz (12 CPUs), ~3.6GHz
             Memory: 16384MB RAM
Available OS Memory: 16334MB RAM
          Page File: 4255MB used, 28408MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 690
       Manufacturer: NVIDIA
          Chip type: NVxx
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_1188&SUBSYS_26903842&REV_A1
     Display Memory: 4014 MB
   Dedicated Memory: 1966 MB
      Shared Memory: 2047 MB
       Current Mode: 1366 x 768 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: PanasonicTV0
         Monitor Id: MEIA0D7
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: DVI
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.0623 (English)
     Driver Version: 9.18.13.623
        DDI Version: 11
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 8/30/2012 15:14:00, 18229096 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B71E3E-52C8-11CF-9D59-9D061CC2C435}
          Vendor ID: 0x10DE
          Device ID: 0x1188
          SubSys ID: 0x26903842
        Revision ID: 0x00A1
 Driver Strong Name: oem16.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section085:9.18.13.623:pci\ven_10de&dev_1188
     Rank Of Driver: 00E02001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Speakers (Sound Blaster X-Fi Xtreme Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_1102&DEV_000A&SUBSYS_11021006&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: t3.sys
         Driver Version: 6.10.0000.0209 (English)
            WHQL Logo'd: Yes
          Date and Size: 5/6/2009 02:34:52, 639512 bytes
            Other Files:
        Driver Provider: CREATIVE
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Digital Audio (S/PDIF) (Sound Blaster X-Fi Xtreme Audio)
 Default Sound Playback: No
 Default Voice Playback: No
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: t3.sys
            WHQL Logo'd: Yes
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
            Description: PanasonicTV0-2 (NVIDIA High Definition Audio)
            Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0040&SUBSYS_38422690&REV_1001
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: nvhda64v.sys
         Driver Version: 1.03.0018.0000 (English)
            WHQL Logo'd: Yes
          Date and Size: 7/3/2012 11:25:16, 189288 bytes
            Other Files:
        Driver Provider: NVIDIA Corporation
              Cap Flags: 0xF1F
              HW Memory: 0
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
            Driver Name: t3.sys
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: HID-compliant consumer control device
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0xFEEB, 0xDEEF
        FF Driver: n/a
      Device Name: G9x Laser Mouse
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC066
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Gaming Keyboard G110
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC22A
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: G110 G-keys
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC22B
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1D2D
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Service: kbdhid
| Service: kbdhid
| Vendor/Product ID: 0x046D, 0xC232
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Logitech HID-compliant G9x Laser Mouse
| Matching Device ID: hid\vid_046d&pid_c066&mi_00
| Upper Filters: LMouFilt
| Lower Filters: LHidFilt
| Service: mouhid
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC231
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 9.8 GB
Total Space: 57.1 GB
File System: NTFS
      Model: INTEL SSDSC2CT060A3 ATA Device
      Drive: E:
 Free Space: 1907.6 GB
Total Space: 1907.7 GB
File System: NTFS
      Model: ST2000DM001-9YN164 ATA Device
      Drive: D:
      Model: HL-DT-ST BDDVDRW UH12LS29 SCSI CdRom Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 I/O APIC - 3C2C
Device ID: PCI\VEN_8086&DEV_3C2C&SUBSYS_50001458&REV_07\3&11583659&1&2C
   Driver: n/a
     Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_50011458&REV_A6\3&11583659&1&F0
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Root Port 7 - 1D1C
Device ID: PCI\VEN_8086&DEV_1D1C&SUBSYS_50011458&REV_B6\3&11583659&1&E6
   Driver: n/a
     Name: Intel(R) PRO/1000 GT Desktop Adapter
Device ID: PCI\VEN_8086&DEV_107C&SUBSYS_13768086&REV_05\4&4AA8058&0&00F0
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Unicast Register 0 - 3CE8
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_07\3&4F11E61&0&6A
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C84
Device ID: PCI\VEN_8086&DEV_3C84&SUBSYS_3C841458&REV_07\3&4F11E61&0&44
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_1102&DEV_0009&SUBSYS_00181102&REV_00\5&14171DB&0&000018
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 2 - 3CAC
Device ID: PCI\VEN_8086&DEV_3CAC&SUBSYS_3CAC1458&REV_07\3&4F11E61&0&7C
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 3 - 3CB5
Device ID: PCI\VEN_8086&DEV_3CB5&SUBSYS_3CB51458&REV_07\3&4F11E61&0&85
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Interrupt Control Registers - 3CE0
Device ID: PCI\VEN_8086&DEV_3CE0&SUBSYS_3CE01458&REV_07\3&4F11E61&0&58
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Control Status and Global Errors - 3C2A
Device ID: PCI\VEN_8086&DEV_3C2A&SUBSYS_50001458&REV_07\3&11583659&1&2A
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset LPC Controller - 1D41
Device ID: PCI\VEN_8086&DEV_1D41&SUBSYS_50011458&REV_06\3&11583659&1&F8
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Root Port 6 - 1D1A
Device ID: PCI\VEN_8086&DEV_1D1A&SUBSYS_50011458&REV_B6\3&11583659&1&E5
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_07\3&4F11E61&0&69
   Driver: n/a
     Name: Fresco Logic xHCI (USB3) Controller FL1009 Series
Device ID: PCI\VEN_1B73&DEV_1009&SUBSYS_50071458&REV_02\4&2714E35A&0&00E5
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 0 - 3C83
Device ID: PCI\VEN_8086&DEV_3C83&SUBSYS_3C831458&REV_07\3&4F11E61&0&43
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 1 - 3CAB
Device ID: PCI\VEN_8086&DEV_3CAB&SUBSYS_3CAB1458&REV_07\3&4F11E61&0&7B
   Driver: n/a
     Name: NVIDIA GeForce GTX 690
Device ID: PCI\VEN_10DE&DEV_1188&SUBSYS_26903842&REV_A1\6&13B9532&0&00800010
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 2 - 3CB4
Device ID: PCI\VEN_8086&DEV_3CB4&SUBSYS_3CB41458&REV_07\3&4F11E61&0&84
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 3 - 3CD0
Device ID: PCI\VEN_8086&DEV_3CD0&SUBSYS_3CD01458&REV_07\3&4F11E61&0&53
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Address Map, VTd_Misc, System Management - 3C28
Device ID: PCI\VEN_8086&DEV_3C28&SUBSYS_50001458&REV_07\3&11583659&1&28
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Virtual Root Port - 1D3E
Device ID: PCI\VEN_8086&DEV_1D3E&SUBSYS_50001458&REV_06\3&11583659&1&88
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_07\3&4F11E61&0&68
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Root Port 4 - 1D16
Device ID: PCI\VEN_8086&DEV_1D16&SUBSYS_50011458&REV_B6\3&11583659&1&E3
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 0 - 3C80
Device ID: PCI\VEN_8086&DEV_3C80&SUBSYS_3C801458&REV_07\3&4F11E61&0&40
   Driver: n/a
Device ID: PCI\VEN_1B73&DEV_1009&SUBSYS_50071458&REV_02\4&177D82FA&0&00E6
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 0 - 3CAA
Device ID: PCI\VEN_8086&DEV_3CAA&SUBSYS_3CAA1458&REV_07\3&4F11E61&0&7A
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_1188&SUBSYS_26903842&REV_A1\6&10307E9D&0&00400010
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 1 - 3CB3
Device ID: PCI\VEN_8086&DEV_3CB3&SUBSYS_3CB31458&REV_07\3&4F11E61&0&83
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 2 - 3CC2
Device ID: PCI\VEN_8086&DEV_3CC2&SUBSYS_3CC21458&REV_07\3&4F11E61&0&52
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 3c - 3C0A
Device ID: PCI\VEN_8086&DEV_3C0A&SUBSYS_3C0A8086&REV_07\3&11583659&1&1A
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_07\3&4F11E61&0&62
   Driver: n/a
     Name: Intel(R) 6 Series/C200 Series Management Engine Interface - 1D3A
Device ID: PCI\VEN_8086&DEV_1D3A&SUBSYS_1C3A1458&REV_05\3&11583659&1&B0
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Root Port 3 - 1D14
Device ID: PCI\VEN_8086&DEV_1D14&SUBSYS_50011458&REV_B6\3&11583659&1&E2
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller RAS Registers - 3C71
Device ID: PCI\VEN_8086&DEV_3C71&SUBSYS_3C711458&REV_07\3&4F11E61&0&79
   Driver: n/a
     Name: Standard AHCI 1.0 Serial ATA Controller
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_B0001458&REV_11\4&3A795F3C&0&00E2
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Registers - 3CA8
Device ID: PCI\VEN_8086&DEV_3CA8&SUBSYS_3CA81458&REV_07\3&4F11E61&0&78
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 0 - 3CB2
Device ID: PCI\VEN_8086&DEV_3CB2&SUBSYS_3CB21458&REV_07\3&4F11E61&0&82
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_26903842&REV_A1\6&13B9532&0&01800010
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 1 - 3CC1
Device ID: PCI\VEN_8086&DEV_3CC1&SUBSYS_3CC11458&REV_07\3&4F11E61&0&51
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_07\3&4F11E61&0&61
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 3a in PCI Express Mode - 3C08
Device ID: PCI\VEN_8086&DEV_3C08&SUBSYS_50001458&REV_07\3&11583659&1&18
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #2 - 1D2D
Device ID: PCI\VEN_8086&DEV_1D2D&SUBSYS_50061458&REV_06\3&11583659&1&D0
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Root Port 2 - 1D12
Device ID: PCI\VEN_8086&DEV_1D12&SUBSYS_50011458&REV_B6\3&11583659&1&E1
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent Performance Monitoring - 3C46
Device ID: PCI\VEN_8086&DEV_3C46&SUBSYS_3C461458&REV_07\3&4F11E61&0&71
   Driver: n/a
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_B0001458&REV_11\4&2AE1FEDC&0&00E1
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Processor Home Agent - 3CA0
Device ID: PCI\VEN_8086&DEV_3CA0&SUBSYS_3CA01458&REV_07\3&4F11E61&0&70
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 1 - 3CB1
Device ID: PCI\VEN_8086&DEV_3CB1&SUBSYS_3CB11458&REV_07\3&4F11E61&0&81
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_26903842&REV_A1\6&10307E9D&0&01400010
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Power Control Unit 0 - 3CC0
Device ID: PCI\VEN_8086&DEV_3CC0&SUBSYS_3CC01458&REV_07\3&4F11E61&0&50
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_3CE8&SUBSYS_3CE81458&REV_07\3&4F11E61&0&60
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 2a - 3C04
Device ID: PCI\VEN_8086&DEV_3C04&SUBSYS_50001458&REV_07\3&11583659&1&10
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26
Device ID: PCI\VEN_8086&DEV_1D26&SUBSYS_50061458&REV_06\3&11583659&1&E8
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 1 Performance Monitor - 3C45
Device ID: PCI\VEN_8086&DEV_3C45&SUBSYS_3C451458&REV_07\3&4F11E61&0&9E
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Root Port 1 - 1D10
Device ID: PCI\VEN_8086&DEV_1D10&SUBSYS_50011458&REV_B6\3&11583659&1&E0
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 System Address Decoder - 3CF6
Device ID: PCI\VEN_8086&DEV_3CF6&SUBSYS_3CE81458&REV_07\3&4F11E61&0&67
   Driver: n/a
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_B0001458&REV_11\4&20502B8B&0&00E0
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C94
Device ID: PCI\VEN_8086&DEV_3C94&SUBSYS_3C941458&REV_07\3&4F11E61&0&4C
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Channel 0-3 Thermal Control 0 - 3CB0
Device ID: PCI\VEN_8086&DEV_3CB0&SUBSYS_3CB01458&REV_07\3&4F11E61&0&80
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DDRIO - 3CB8
Device ID: PCI\VEN_8086&DEV_3CB8&SUBSYS_3CB81458&REV_07\3&4F11E61&0&88
   Driver: n/a
     Name: PCI Express standard Upstream Switch Port
Device ID: PCI\VEN_10B5&DEV_8747&SUBSYS_874710B5&REV_BA\UBA870010B5DF0E0000
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QuickPath Interconnect Agent Ring Registers - 3CE6
Device ID: PCI\VEN_8086&DEV_3CE6&SUBSYS_3CE61458&REV_07\3&4F11E61&0&9C
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 IIO PCI Express Root Port 1a - 3C02
Device ID: PCI\VEN_8086&DEV_3C02&SUBSYS_50001458&REV_07\3&11583659&1&08
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to QuickPath Interconnect Link 0 Performance Monitor - 3C44
Device ID: PCI\VEN_8086&DEV_3C44&SUBSYS_3C441458&REV_07\3&4F11E61&0&9D
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset SMBus Host Controller - 1D22
Device ID: PCI\VEN_8086&DEV_1D22&SUBSYS_50011458&REV_06\3&11583659&1&FB
   Driver: n/a
     Name: Intel(R) C600 Series Chipset SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1D02&SUBSYS_B0021458&REV_06\3&11583659&1&FA
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 1 - 3CF5
Device ID: PCI\VEN_8086&DEV_3CF5&SUBSYS_3CE81458&REV_07\3&4F11E61&0&6E
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link Reut 1 - 3C93
Device ID: PCI\VEN_8086&DEV_3C93&SUBSYS_3C931458&REV_07\3&4F11E61&0&4B
   Driver: n/a
     Name: Atheros AR5BWB222 Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_0034&SUBSYS_662111AD&REV_01\4&31EE24F&0&00E3
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 4 - 3CAE
Device ID: PCI\VEN_8086&DEV_3CAE&SUBSYS_3CAE1458&REV_07\3&4F11E61&0&7E
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 3 - 3CB7
Device ID: PCI\VEN_8086&DEV_3CB7&SUBSYS_3CB71458&REV_07\3&4F11E61&0&87
   Driver: n/a
     Name: PCI Express standard Downstream Switch Port
Device ID: PCI\VEN_10B5&DEV_8747&SUBSYS_874710B5&REV_BA\BA870010B5DF0E0080
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 R2PCIe - 3CE4
Device ID: PCI\VEN_8086&DEV_3CE4&SUBSYS_3CE41458&REV_07\3&4F11E61&0&98
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Ring to PCI Express Performance Monitor - 3C43
Device ID: PCI\VEN_8086&DEV_3C43&SUBSYS_3C431458&REV_07\3&4F11E61&0&99
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 DMI2 - 3C00
Device ID: PCI\VEN_8086&DEV_3C00&SUBSYS_50001458&REV_07\3&11583659&1&00
   Driver: n/a
     Name: Intel(R) C600/X79 series chipset PCI Express Root Port 8 - 1D1E
Device ID: PCI\VEN_8086&DEV_1D1E&SUBSYS_50011458&REV_B6\3&11583659&1&E7
   Driver: n/a
     Name: Intel(R) 82579V Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_E0001458&REV_06\3&11583659&1&C8
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller System Address Decoder 0 - 3CF4
Device ID: PCI\VEN_8086&DEV_3CF4&SUBSYS_3CE81458&REV_07\3&4F11E61&0&66
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 QPI Link 1 - 3C90
Device ID: PCI\VEN_8086&DEV_3C90&SUBSYS_3C901458&REV_07\3&4F11E61&0&48
   Driver: n/a
     Name: PCI standard PCI Express to PCI/PCI-X Bridge
Device ID: PCI\VEN_1102&DEV_7006&SUBSYS_00101102&REV_00\4&29F5A0FA&0&0018
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller Target Address Decoder 3 - 3CAD
Device ID: PCI\VEN_8086&DEV_3CAD&SUBSYS_3CAD1458&REV_07\3&4F11E61&0&7D
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Integrated Memory Controller ERROR Registers 2 - 3CB6
Device ID: PCI\VEN_8086&DEV_3CB6&SUBSYS_3CB61458&REV_07\3&4F11E61&0&86
   Driver: n/a
Device ID: PCI\VEN_10B5&DEV_8747&SUBSYS_874710B5&REV_BA\BA870010B5DF0E0040
   Driver: n/a
     Name: Intel(R) Xeon(R) Processor E5 Product Family/Core i7 Semaphore and Scratchpad Configuration Registers - 3CE3
Device ID: PCI\VEN_8086&DEV_3CE3&SUBSYS_3CE31458&REV_07\3&4F11E61&0&5B
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
CyberLink RealMedia Splitter,0x00600000,1,1,CLRMSplitter.ax,1.00.0000.1103
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
CyberLink Editing Service 5.0 (Source),0x00200000,0,2,CLEdtKrn.dll,5.05.0000.2626
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.01.0004.0000
Cyberlink Track Filter,0x00200000,1,1,YCTrack.ax,1.01.0000.0222
CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,SE_CLEdtDemuxer.ax,1.02.0002.2311
CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
PP TV Audio Decoder,0x00200000,1,1,claudTV.ax,6.00.0000.4104
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
CyberLink Audio Wizard,0x00201010,1,1,CLAudWizard.ax,1.00.0000.4414
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.5113
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,CLEdtDemuxer.ax,1.02.0001.7826
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
BPM Metadata,0x001fffff,1,1,MetaBPMu.ax,2.00.0002.0000
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.6108
Creative Recording Wav_Asio Filter,0x00400000,0,1,AudioRec.ax,1.00.0002.0000
CyberLink Line21 Decoder (PDVD10),0x00200000,0,2,CLLine21.ax,4.00.0000.10324
CyberLink Matroska Splitter,0x00200000,1,2,CLMKVSplter.ax,1.00.0000.1329
Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.02.0001.3026
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
CyberLink DVD Navigator (PDVD10),0x00200000,0,3,CLNavX.ax,8.01.0000.3411
PP Video Decoder,0x00200000,2,3,ppGenericVSD.ax,6.00.4900.9516
CyberLink AudioCD Filter (PDVD10),0x00200000,0,1,CLAudioCD.ax,5.00.0000.7823
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0009.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
PP Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,2.00.0000.4301
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
PP Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.4900.9516
CyberLink Matroska Splitter(PDVD10),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.1902
CyberLink TimeStretch Filter (PDVD10),0x00200000,1,1,clauts.ax,2.00.0000.3404
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
CyberLink RealMedia Splitter(PDVD10),0x00600000,1,1,CLRMSplitter.ax,1.00.0000.1706
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
YC_EVRWindow,0x00200000,0,0,YCEvr.dll,1.00.0001.4504
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
PP Dump Filter,0x00200000,1,0,CLDump.ax,3.00.0000.10814
CyberLink MPEG-4 Splitter,0x00200000,1,2,SE_clm4splt.ax,1.01.0000.2309
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,2.00.0000.1610
CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.3408
CyberLink Mux Push Source,0x00200000,0,1,SE_CLMuxPushSrc.ax,1.00.0000.3509
CyberLink FLV Splitter,0x00800001,1,1,CLFLVSplitter.ax,1.00.0000.1117
PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
CyberLink Audio Decoder (PDVD10),0x00201000,1,1,Claud.ax,8.04.0000.4528
CyberLink Video/SP Decoder (PDVD10),0x00602000,2,3,CLVsd.ax,8.04.0000.2505
Creative Normalize,0x00200000,1,1,AudNrm.ax,1.00.0001.0000
CyberLink HD/BD Mixer (PDVD10),0x00200000,1,2,CLHBMixer.ax,2.00.0000.3407
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
PP TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.03.0000.1917
PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.2523
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,6.00.0002.0000
PP DV TCR,0x00200000,1,1,ppDVTCR.ax,2.01.0000.6525
CyberLink Video Decoder,0x00700100,1,2,clcvd.ax,1.00.0000.1230
Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0012.0000
CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
CyberLink Audio Effect (PDVD10),0x00200000,1,1,ClAudFx.ax,6.00.0000.7225
PP Audio Encoder,0x00200000,2,0,CLAudEnc.ax,2.01.0000.1926
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Creative AC3 Source Filter,0x00400000,0,1,AC3Srcu.ax,3.02.0001.0000
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.01.0000.2928
CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
Creative PCM Raw Writer,0x00200000,1,0,RawWritu.ax,1.00.0000.0000
CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
PP MPEG Muxer,0x00200000,2,1,MpgMux.ax,5.02.0000.2424
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
CyberLink Frame Parser,0x00200000,2,0,CLFParser.ax,1.00.0000.3702
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17835
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Audio Progress Filter,0x001fffff,1,1,AudProg.ax,1.00.0002.0000
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
CyberLink MPEGV Analyzer,0x00200000,1,1,SE_CLMPEGVAnalyzer.ax,1.00.0000.3512
CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
CyberLink SBE Source Filter,0x00200000,0,0,CLSBESrc.ax,1.00.0000.3628
CyberLink AVCHD Navigator,0x00600000,0,3,CLAVCHDNav.ax,2.00.0000.4516
CyberLink Digest Filter (PDVD10),0x00200000,2,2,DigestFilter.dll,1.00.0000.4028
Cyberlink Dump Dispatch Filter,0x00200000,1,0,SE_CLDumpDispatch.ax,1.03.0000.3509
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0008.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
CyberLink Stamp Effect,0x00200000,1,1,ppStampEffect.ax,1.00.0000.4125
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.7830
Creative Flac Source Filter,0x00400000,0,1,FlacSrcu.ax,1.00.0002.0000
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
Creative MLP Source Filter,0x00400000,0,1,MlpSrcu.ax,3.01.0000.0000
Creative File Reader Filter,0x00400000,0,1,FilReadu.ax,1.00.0005.0000
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
SVM Metadata,0x001fffff,1,1,MetaSVMu.ax,2.00.0002.0000
Cyberlink SubTitle Importor (PDVD10),0x00200000,2,1,CLSubTitle.ax,2.00.0000.1823
Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
Creative EQ,0x00200000,1,1,AudioEQ.ax,1.00.0001.0000
CyberLink TL MPEG Splitter,0x00200000,1,2,SE_CLTLMSplter.ax,3.04.0000.2309
CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
PP Audio Effect,0x00200000,1,1,CLAudFx.ax,6.01.0000.3122
PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
CyberLink RealVideo Decoder,0x00600000,1,1,CLRMVD.ax,1.00.0000.1021
CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
CyberLink TL MPEG Splitter,0x00200000,1,2,YCTLMSplter.ax,3.02.0000.2219
CyberLink Audio Decoder,0x00200000,1,1,SE_claud.ax,8.03.0000.2407
PP Audio Decoder,0x00200000,1,1,CLAud.ax,8.03.0000.2417
CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
CyberLink SnapShotTIP Filter,0x00200000,1,1,CLSShot.ax,1.00.0000.4022
PP MPEG Splitter,0x00200000,1,2,ppSplter.ax,3.03.0000.1917
Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17835
PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.3319
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,3.00.0000.2118
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
CyberLink H.264/AVC Decoder,0x00200000,1,2,cl264dec.ax,2.01.5330.5916
CyberLink HAM Decoder,0x00600000,0,1,clcvd.ax,1.00.0000.1230
PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
Peak Filter,0x001fffff,1,1,AudPeak.ax,1.00.0002.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
Creative Ogg Source Filter,0x00400000,0,1,OggSrcu.ax,1.00.0001.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
Creative NVF Filter,0x00400000,0,1,NvfSrcu.ax,3.01.0001.0000
CyberLink Tzan Filter (PDVD10),0x00200000,1,1,CLTzan.ax,3.05.0000.4515
PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0007.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
CyberLink WebCamera NULL Render,0x00200000,0,0,YCWEBCAMERARENDER.ax,2.00.10175.3910
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,5.00.0001.0000
CyberLink RealVideo Decoder(PDVD10),0x00600000,1,1,CLRMVD.ax,1.00.0000.1225
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
CyberLink Video Regulator,0x00200000,1,1,YCRgl.ax,3.00.0000.1228
Cyberlink SubTitle Importor 2.0 (PDVD10),0x00200000,1,0,CLSubTitle.ax,2.00.0000.1823
CyberLink MPEGV Analyzer,0x00200000,1,1,CLMPEGVAnalyzer.ax,1.00.0000.3618
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0001.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17835
CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
CyberLink RealAudio Decoder,0x00600000,1,1,CLRMAud.ax,1.00.0000.1106
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
CyberLink Video Decoder (PDVD10),0x00200000,1,2,CLCvd.ax,1.00.0030.3327
PP Video Regulator,0x00200000,1,1,CLRGL.ax,3.00.0000.2430
PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,1.00.0000.2617
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
CyberLink WMV Dumper,0x00200000,2,0,YCWMVDump.ax,1.00.0000.2625
CyberLink SBE Filter,0x00200000,0,0,CLSBE.ax,1.00.0000.3628
CyberLink MPEG-4 Splitter (PDVD10),0x00600000,1,2,clm4splt.ax,1.01.0000.2906
CyberLink RealAudio Decoder(PDVD10),0x00600000,1,1,CLRMAud.ax,1.00.0000.1225
CyberLink MPEG Muxer,0x00200000,2,1,SE_MpgMux.ax,5.02.0000.2311
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
CyberLink MPEG-4 Muxer,0x00200000,1,1,SE_clm4muxer.ax,1.05.0000.1109
PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0003.0000
PP MPEG Video Encoder,0x00200000,1,1,CLVidEnc.ax,6.04.0001.3511
Creative LiveRecording Filter SxS,0x00400000,0,1,LiveRecu.ax,5.00.0001.0000
CyberLink FLV Splitter(PDVD10),0x00800001,1,1,CLFLVSplitter.ax,1.00.0000.2027
Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.2518
Creative Internet Source Filter,0x00400000,0,1,InetSrcu.ax,1.00.0000.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.4024
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
CyberLink MPEG-4 Splitter,0x00200000,1,2,clm4splt.ax,1.00.0000.6622
CyberLink MPEG-4 Muxer,0x00200000,1,1,clm4muxer.ax,1.00.0000.4724
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Digital Audio (S/PDIF) (Sound B,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Sound Blaster X-Fi Xtreme Audio S/PDIF-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
Sound Blaster X-Fi Xtreme Audio Mic-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Sound Blaster X-Fi Xtreme Audio Line-In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
Sound Blaster X-Fi Xtreme Audio S/PDIF-Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
,0x00000000,0,0,,
,0x00000000,0,0,,
Sound Blaster X-Fi Xtreme Audio Line-Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
CyberLink Web Camera Filter,0x00200000,0,1,YCWebCameraSource.ax,2.00.10175.3910
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Sound Blaster X-Fi Xt,0x00200000,1,0,quartz.dll,6.06.7601.17713
CyberLink Audio Renderer (PDVD10),0x00200000,1,0,cladr.ax,7.00.0000.4422
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
Digital Audio (S/PDIF) (Sound B,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Digital Audio (S/PDIF) (Sound Blaster X-Fi Xtreme Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: PanasonicTV0-2 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Sound Blaster X-Fi Xtreme Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
PanasonicTV0-2 (NVIDIA High Def,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
180GB SSDs are now under $100, but even when I had a mechanical HD, I still moved those folders away from C: Drive as soon as I installed Windows and before installing any Apps. It makes imaging/reimaging quicker.
You are moving the location of your existing user profile, not new user profile. I move the location of Documents, Desktop, Start Menu, Favorites, etc. as well. That way they are not affected by frequent drive imaging.
@c627627: Yes, that is exactly what i'd like to do as well. My question is, how do I go about doing that? "I move the location of Documents, Desktop, Start Menu, Favorites, etc. as well. That way they are not affected by frequent drive imaging" <-----I would love to know how to move this stuff and my existing user profile as well, to E:. Oh, and i've decided to do a clan install of windows 7 on my PC so that I can start fresh. So, assuming i've just completed that install, how do I move all of that stuff? thanks.
Registry Edits, even CUT/PASTE used to work on older versions of Windows when it comes to Desktop, Start Menu, Favorites. But before I figured those out, I used TweakUI made by Microsoft.
I am assuming you are using a 64-Bit OS, so use the 64-Bit version of that freeware program. It should be under the My Computer TAB when you start it.
Let me know if it worked as I've never tried the 64-Bit version. All versions are attached here, but use the 64-Bit one for 64-Bit Windows:
  • TweakUI.zip
Click on the start menu and then on your user account name, it should bring up a window of all the shortcuts to My Documents, Music, Pictures, etc.
Right click on them and open Properties
Click on the Location tab
Click the Move button and choose a folder on your 2TB hard drive where the current files and future files will be stored.
However, in terms of moving AppData, I'm not sure how to point that to another drive. Maybe the program that c627627 mentioned will do that (I've never used TweakUI)
