Trinity On The Desktop: A10, A8, And A6 Get Benchmarked!
Have not read it myself yet, will take my time with it later
While it still might not compete with a Stars core it certainly rocks a Bulldozer clock for clock and core for core. Here's to hoping this trend continues for the Vision and the next iterations.
Quoted for reference.Yes, it seems the performance has improved 15% clock for clock, which is exactly what AMD promised.
So it is 15% faster than Bulldozer clock for clock, that still has it trailing Phenom II, but not by much now and we are going to be looking at ~20% higher clock speeds over Phenom II.
So it will be faster than Phenom II, perhaps by 10% stock, the fact that it has 8 cores will make it more pronounced where they are used against Thuban and IB.
It will not match IB with 4 cores, but it might get close enough to it and when 8 are in use.... dare i say it?
Beyond that it depends on overclocking, how high can it go?
AMD FX-8350 Q3 / Q4
I was around reviewing CPUs back when single-core processors started giving way to dual-core chips. Back then, nothing was optimized for threading aside from server-oriented apps. Software developers had to reorient themselves before multi-core desktop CPUs made sense. But it happened. Just look at how much of our suite favors the quad-core APUs over A6-5400K. Scaling clock rate indefinitely proved impossible, so AMD and Intel went wide instead.
The same re-orientation has to happen before the idea that you buy a graphics card for more than gaming is really true (I don’t think it is yet, despite AMD’s claims). That process is happening right now, though, and you can see the momentum building. We expect to see companies like CyberLink on the bleeding edge of technology because it gives them a competitive advantage amongst early adopters. Corel and Adobe aren’t there until it’s ready for prime time. And yet, here they are.
Hmmmm, very nice. Lets hope these little suckers overclock to the moon and back. I want the AM3+ variant though damnit!
I'm waiting for it. I'll buy it. I'm not sure what to do with my current chip though. Possibly toss it in my HTPC. I believe the idle power use of the 8120 is less than its current 955BE
I think my old Thuban was the best buy I ever had. $60 though it had gone under water in the floods. Overclocked reasonably well and performed better than my current chip in a couple of things. Most notably Handbrake..... A good thing I only convert videos occasionally. Still annoying though.
I kind of wish I could stop spending money on this stuff..... My last 3 upgrades have been completely unnecessary..... Thing is I can't stop reading and thinking about it until I buy and play with the stuff..... I wish they'd released a 6 module pd chip because I want it
Lol. Yep. Me too. Now doesn't ten or twelve cores sound like a must have despite absolutely nothing being able to use it?
You know, since moving from 4 cores its never happened. Everything runs the same regardless of what's running. Even with IntelBurnTest running on Max settings the system is fast and useable
