- Sep 7, 2013
- Thread Starter
- #21
They should have called it "Service Pack 5"
You were talking about Windows XP/Neptune dual boot.
If you install EasyBCD on Windows XP, then after installing Neptune on another partition, EasyBCD can be used to switch between Windows Xp and Neptune. So You run EasyBCD after installing Neptune on another partition and then EasyBCD detects it and you use EasyBCD to modify boot.ini files.
You can and should install EasyBCD on both Windows XP and Neptune and use EasyBCD from both Windows Xp and Neptune to switch which default OS is setup to boot in.
I am not talking about DOS because it is not clear if EasyBCD can be use to multiboot DOS with OS from Windows 95 to present. i would like to know the answer to that question, if you find that out through search or through experimentation please post.
That drive is on borrowed time, I suggest retiring it before it drives you crazy with the unpredictable behavior that results from dying hard drives.
There is a button for "Add Entry" and you need to add the new Entry manually for Windows XP and for Neptune and for Windows 98.
Maybe DOS works too, maybe it doesn't.
Make sure you select correct Type from the drop down menu and correct corresponding drive letter.
Maybe you need to UNCHECK: Automatically detect correct drive and do that manually too.
EasyBCD has a forum: http://neosmart.net/forums/forumdisplay.php?f=7
I would start a thread there.
I myself was able to install different OSs, Windows 9x/Me/2000/XP and simply manually setup entries as described above. Anything beyond that, you would either need to figure out how to setup the boot.ini file or start a thread at the EasyBCD forum.
That is too bad.
Please post if you find another loader, otherwise, we'll have to figure out how to manually set the boot.ini files.
What method do you use to "find" the bad spot then create a partition over it then hide the partition to make clicks of death stop? That's a very ingenious way to save a drive that's not all that important and just have a system to play around with like you are doing now, I'm just having trouble understanding how you could know which parts to partition and cut off from the rest, but if it stops the clicks of death that initself is interesting.
Is there a need for a separate partition for xosl? Can it work from Win9x and from other OSs?
