- Oct 12, 2005
So, I've had my setup for a while now:
MSI K7N2 Delta
AMD Athlon XP 3000+
Two sticks of 512mb PC3200 DDRAM
More than adequate cooling with fans (I have lots of fans and my temps are always reasonable, CPU averaging 30 degrees celcius and case temp around 40-45)
GeForce FX5200 graphics card (128mb DDR)
Recently I've been messing around with overclocking. I started off by upping the FSB speed from its default 166mhz to 177mhz (my mobo lets me go up to 200 in intervals of 1mhz). But if I brought it any further, my system would become unstable and either crash in windows or simply not boot. Thinking I wasn't giving the processor enough voltage, I tried increasing the VCore voltage from it's standard 1.65v to 1.70v, but even such a small jump resulted in instability. Next I tried to bring the multiplier clock lower to increase FSB, but again more instability. I've been tampering with some of the other setting in BIOS, including memory timing, but seem to only end up causing more crashing and trouble booting. At the moment I'm running with my FSB at 177mhz, my CAS Latency at 3, and my other memory timings pretty relaxed. Everything seems to be running fine, however, when I run a stress test on Prime95, it immediately finds a hardware error and if I try to play any demanding game it will crash.
Is there anybody out there who can help guide me through the process of overclocking this system? I've gone through quite a bit of experimentation and have only been able to up my clocking speed from 2166mhz to 2303mhz, and with problems at that. Any help or tips would be greatly appreciated.
MSI K7N2 Delta
AMD Athlon XP 3000+
