- Nov 1, 2001
- New Iberia, LA
- Thread Starter
- #41
I think part of the problem with this case and 38 mm thick fans in a push-pull setup is that it just runs out of room on the back side of the heatsink for good airflow from the pull fan. It's not nearly as bad with the 25 mm thick fans with either heatsink. And with the Mega being a little thicker in cross section than the TRUE, I think it affects the airflow even more than the TRUE. Here are some pics of both heatsinks with 38 mm thick fans in push-pull in this old case.
This is the Megahalems in push-pull with the Panaflo fans:
This is the TRUE with those fans:
And here is thr TRUE with the S-Flex fans mounted:
I didn't take a pic of the Megahalems with 25 mm thick fans in push-pull, but it's much like the TRUE except with about 1/8" less clearance to the back of the case.
I do plan to do some mods to this case in the near future. I plan to replace those 80 mm exhaust fans with 92 mm Panaflo M1BX fans and to give more room for a push-pull config. I plan to mount the fans externally to the back of the case instead of internally.
