Mhill11
- Jan 26, 2014
- Des Moines IA
After reading multiple threads and stickies across multiple forums I have more knowledge from when I started looking into water cooling (which was absolutely nothing),but still not a 100% sure on whats the best route. At first I was thinking of an EK kit, probably the H30 360 HFX but there seems to be a lot of ppl against EK's kits. Ideally I want to try and get a kit that can handle 3 blocks.
First off I'm thinking that Raystorms AX360 extreme will start me off good with the dual D5's but would the Rad effectively cool 3 blocks? or should I look into getting a 2nd Rad also?
secondly, could a single D5 effectively cool 3 blocks with 2 RADS?
Ive been able to budget most of these setups at or around 600$ which is the budget i have set aside for this project.
The biggest thing I'm currently having trouble with right now is will 2 D5's and a 360 Rad cool 3 blocks effectively? if not will an added 120 or 240 Rad help handle 3 blocks?
i5 4670K - mosfet - and the southbridge are the items I'm trying to cool
any and all help will be much appreciated.
