Trying to get a new psu
Dino-Man
AJ Arizona
So ive heard of -5v stuff and 20 and 24 pins and i wanted to make sure i get the best psu i can possibly buy. Im looken to buy a dual core X2 AM2 with a 2.6GHz and more kingston ram 1g x2. So in the future i will buy a 8800 gt if the price continues to go down.
Here are my specs
Not sure if this gives you my psu info
but heres the basic its a antec 400 watt PSU
Please give me your thoughts and suggestions.
I can't thank you enough for all you tech experts out there its people like you that really teach people like me. :)
System Information
Time of this report: 3/4/2008, 20:52:06
Machine name: CARLOS-APIVYCLS
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3500+, MMX, 3DNow, ~2.2GHz
Memory: 1024MB RAM
Page File: 411MB used, 2049MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8600 GT
Chip type: GeForce 8600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0402&SUBSYS_40161682&REV_A1
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6921 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/5/2007 01:41:00, 5773568 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/5/2007 01:41:00, 7435392 bytes
Device Identifier: {D7B71E3E-4742-11CF-3B6E-1D6000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0402
SubSys ID: 0x40161682
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_10DE&DEV_0059&SUBSYS_1B131019&REV_A2
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5950 (English)
WHQL Logo'd: Yes
Date and Size: 10/26/2005 01:08:26, 3786944 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 26, 25
Static/Strm HW 3D Bufs: 26, 25
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HID-compliant consumer control device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1267, 0x0103
FF Driver: n/a
Device Name: HID-compliant device
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x005A
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/29/2002 05:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x046D, 0xC50E
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/3/2004 23:08:20, 36224 bytes
| | Driver: hidparse.sys, 8/3/2004 23:08:18, 24960 bytes
| | Driver: hid.dll, 8/4/2004 00:56:44, 20992 bytes
| | Driver: hidusb.sys, 8/17/2001 14:02:20, 9600 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 8/3/2004 22:58:34, 23040 bytes
| | | Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/3/2004 22:58:36, 14848 bytes
| Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 51.2 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD800JB-00JJC0
Drive: D:
Model: LITE-ON DVDRW SHM-165H6S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:54, 49536 bytes
Drive: E:
System Devices
Name: Linksys Wireless-G PCI Adapter
Device ID: PCI\VEN_1814&DEV_0301&SUBSYS_00551737&REV_00\4&15B9AB7D&0&3848
Driver: C:\WINDOWS\system32\DRIVERS\rt61.sys, 1.00.0003.0000 (English), 10/27/2005 16:06:30, 356096 bytes
Name: NVIDIA GeForce 8600 GT
Device ID: PCI\VEN_10DE&DEV_0402&SUBSYS_40161682&REV_A1\4&243D7BD0&0&0070
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 7435392 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 5773568 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 385024 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 1089536 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 6901760 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 8523776 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11132 (English), 12/5/2007 01:41:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 6549504 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 3420160 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 1228800 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 3710976 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 2498560 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 12/5/2007 01:41:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 12/5/2007 01:41:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 12/5/2007 01:41:00, 35328 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 12/5/2007 01:41:00, 35328 bytes
Name: nForce4 HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_005E&SUBSYS_00000000&REV_A4\3&2411E6FE&0&00
Driver: n/a
Name: nForce4 PCI-Express Root Port
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_F3\3&2411E6FE&0&68
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_F3\3&2411E6FE&0&60
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_F3\3&2411E6FE&0&58
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&70
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_005C&SUBSYS_00000000&REV_F2\3&2411E6FE&0&48
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005B&SUBSYS_1B131019&REV_A4\3&2411E6FE&0&11
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:44, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005A&SUBSYS_1B131019&REV_A2\3&2411E6FE&0&10
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 17024 bytes
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_10DE&DEV_0059&SUBSYS_1B131019&REV_A2\3&2411E6FE&0&20
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5950 (English), 10/26/2005 01:08:26, 3786944 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0046 (English), 10/23/2005 23:45:16, 90112 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0051 (English), 10/25/2005 23:32:56, 18776064 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/4/2002 22:54:58, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0053 (English), 10/23/2005 23:55:06, 10459648 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0006 (English), 9/15/2005 23:14:36, 157184 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0057&SUBSYS_1B131019&REV_F3\3&2411E6FE&0&50
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.0465 (English), 11/15/2004 00:44:42, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.0465 (English), 11/15/2004 00:43:58, 275072 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.0465 (English), 11/15/2004 00:43:42, 208256 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 11/15/2004 00:40:36, 9728 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 11/15/2004 00:40:36, 9728 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0016 (English), 10/28/2004 23:26:18, 32256 bytes
Name: NVIDIA CK804 ADMA Controller (v2.7)
Device ID: PCI\VEN_10DE&DEV_0055&SUBSYS_1B131019&REV_F3\3&2411E6FE&0&40
Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0475 (English), 11/3/2004 05:58:20, 86144 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 11/3/2004 05:58:22, 294912 bytes
Device ID: PCI\VEN_10DE&DEV_0054&SUBSYS_1B131019&REV_F3\3&2411E6FE&0&38
Name: NVIDIA CK804 Parallel ATA Controller (v2.7)
Device ID: PCI\VEN_10DE&DEV_0053&SUBSYS_1B131019&REV_F3\3&2411E6FE&0&30
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0052&SUBSYS_1B131019&REV_A2\3&2411E6FE&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0050&SUBSYS_00000000&REV_F1\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/29/2002 05:00:00, 35840 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/29/2002 05:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/29/2002 05:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/29/2002 05:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 3/3/2008 17:35:41 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 3/3/2008 17:35:32 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 3/3/2008 17:35:33 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 3/3/2008 17:35:34 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 3/3/2008 17:35:34 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 3/3/2008 17:35:35 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 3/3/2008 17:35:36 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 3/3/2008 17:35:36 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 3/3/2008 17:35:37 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 3/3/2008 17:35:37 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 3/3/2008 17:35:41 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 3/3/2008 17:35:41 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 3/3/2008 17:35:42 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 3/3/2008 17:35:42 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 3/3/2008 17:35:42 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 3/3/2008 17:35:40 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 3/3/2008 17:35:40 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 3/3/2008 17:35:39 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/29/2002 05:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 00:56:46 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:26 733696 bytes
quartz.dll: 6.05.2600.3243 English Final Retail 10/29/2007 15:43:03 1287680 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3243
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0020
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0020
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3243
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0004.0023
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3243
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3243
CyberLink AudioCD Filter (PDVD6),0x00600000,0,1,CLAudioCD.ax,5.00.0000.3114
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Decoder,0x00602000,1,1,CLAud.ax,6.00.0000.2001
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,NeResize.ax,3.02.0000.0020
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
CyberLink Audio Effect (PDVD6),0x00200000,1,1,claudfx.ax,6.00.0000.1223
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3243
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0020
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0020
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0020
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0020
Nero Digital AVC Video Enc,0x00200000,1,2,,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0020
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3243
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1133
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0020
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0020
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,1.00.0000.0072
CyberLink Demux (PDVD6),0x00400000,1,0,cldemuxer.ax,1.00.0000.2905
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0020
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0020
CyberLink Line21 Decoder (PDVD6),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0000
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0020
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1133
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3243
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1133
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0020
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3243
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3243
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
CyberLink Audio Spectrum Analyzer (PDVD6),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0020
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,1.00.0000.0050
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0020
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0020
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
CyberLink Video/SP Decoder,0x00602000,2,3,CLVsd.ax,6.00.0003.1921
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0020
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink DVD Navigator (PDVD6),0x00600000,0,3,CLNavX.ax,6.00.0000.2606
CyberLink TimeStretch Filter (PDVD6),0x00200000,1,1,clauts.ax,1.00.0000.2212
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Cyberlink SubTitle Importor (PDVD6),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0020
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3243
.RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1133
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0020
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Nero Digital Parser,0x00600000,0,3,NDParser.ax,2.00.0002.0020
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1133
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,1.02.0000.0001
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0020
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0020
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,3.02.0000.0020
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0020
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,1.00.0004.0004
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3243
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3243
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3243
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1133
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0020
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0020
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0020
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0020
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0020
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3243
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3243
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3243
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0020
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0020
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0002.0020
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero AAC Parser,0x00400000,1,1,NeAudio.ax,1.00.0004.0023
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0020
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3243
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3243
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0020
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3243
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3243
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3243
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming Capture Devices:
Realtek AC97 Audio,0x00200000,3,3,,5.03.2600.2180
WDM Streaming Rendering Devices:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.3243
CyberLink Audio Renderer (PDVD6),0x00200000,1,0,cladr.ax,6.00.0000.1817
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3243
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming System Devices:
Realtek AC97 Audio,0x00200000,16,2,,5.03.2600.2180
Buy the corsair before another 4 people come in and say the same thing.
it can do most setups that arent crazy. thideras has a 4ghz quad and a hd3870x2 running off one without problems.
Dang 4. ghz!?!?
that must be crazy fast i plan on getting a 8800 gt/s dunno which ones better.
But i hear that quadcore is all the world will be using by the end of 08 is that true?
I have no clue, I don't like amd because slower intel chips beat em so I can't tell you if its good or bad because my first thought is bad(just the letters amd make me think bad). If you can, go intel(just my thought) but only if you don't like amd anymore.
