- Mar 18, 2015
About the only criticism I can find for TeamViewer is the fact that it will not pass audio from Linux to Windows. A recent change in my setup has left me wanting sound for my NAS/etc box and I thought I had found the answer -> http://wp.xin.at/archives/3862
It sounds like it will work. It make sense. But when I get to the part about pulling up teamviwers winecfg file I throw this error
For me this breaks Teamviewer after a restart but can be fixed with uninstall/reinstall so not that big of a deal. But I did run into some part where I had to extrapolate on the intructions and that must be where the error stems from.
Here are the steps I had to re-arrange a bit:
when the author is explaining about what files to backup and which to copy
/usr/lib/libwine.so.1.0 is not a valid path on my setup. my copy of libwine.so.1.0 comes from "/opt/wine-devel/lib/
There is a "wine" directory that is to be copied from wine to teamviewer's wine that is also in a path related to wine-devel.
I had originally thought that the error having to do with version mismatch was because I was taking the binaries from wine-devel instead of a wine-stable (which I cannot find on my system anywhere even though that is my original choice for instiallation). So I started over. I removed wine-stable and teamviewer to start with a clean environment. I rebuilt all the steps but this time used wine-devel and I am still getting the same error message.
Well there's my story guys. Does anyone have a clue what is going on with that error? A way to RDP between linux and Windows (with sound)? Ive googled a bit for replacement RDP clients and it seems there are a few that may pass sound through, but my preferred solution is to get this fix working. Thanks in advance
Code:
Init...
CheckCPU: SSE2 support: yes
Checking setup...
flock: 300: Bad file descriptor
wine client error:0: version mismatch 440/447.
Your wineserver binary was not upgraded correctly,
or you have an older one somewhere in your PATH.
Or maybe the wrong wineserver is still running?
Code:
cp /usr/lib/libwine.so.1.0 /opt/teamviewer/tv_bin/wine/lib
