I have been trying out my new $65 TT 120. I originally installed it with an AeroCool fan rated at 87CFM max 1800RPM. The temps compared to my Zalman cooler were +1 to 3 degrees C.
I was really expecting an 8 to 10 degree drop.
I have now installed the stock Tuniq fan with the manual fan control. At low speed it is nice and quiet but temps are still +1 to 3 degrees compared to the Zalman. At full speed it is louder than loud but the temps do drop 1 to 3 degrees compared to the Zalman. However I cannot live with the noise. All temps on the Zalman are using silent mode set in BIOS. All other OC features the same for both coolers.
Also ever since I installed the TT 120 it takes sometimes up to 3 minutes to post, where it used to POST in about 5 seconds. Additionally BIOS freezes when trying to enter the fan control section. I do not know if these are related to the cooler or not. Specs are in sig.
I now have the TT 120 at half fan speed and the temps are still + 1 to 3 degrees compared to the Zalman. I have reset this thing twice and the results are always the same. I am beginning to think all you guys own stock in Sunbeam/Tuniq
I will re install my Zalman and use this TT 120 on some other project.
EDIT: Now that I just read another thread here where an op had to lap his Thermalright cooler, maybe this is the cause of my problems.The base of the sink was really quite rough when I got it. Should I sand it smooth? What procedure do I have to follow? I can probably find a tut here on this somewhere.
