- Aug 10, 2010
- Sunshine State
EDIT
Nevermind guys.. I've found a suitable alternative.
I'll get:
- Ultra 120 Extreme Rev C
- Delta Fan
- Akasa PWM Fan splitter cable --> Powers the fan straight from the PSU and only goes to MoBo fan header with RPM and PWM wires... so MoBo is safe from overload.
Hello Overclockers...
I've got a question for you...
I'm going over which CPU Cooler to get for my budget build.
The build will consist of:
Case: Xigmatek Utgard
CPU: Phenom 2 555BE
MoBo: MSI 870 - G45
Ram: G.Skill Ripjaws 2x2GB DDR3 1600
I have the GPU, HDDs, Optical and Monitor so that's all I need to buy for now.
I've read good reviews about the Thermaltake Frio all over the web. Probably the only knock on it, is that it is a tad big and will overhang the first RAM slot, but that is to be expected from these things and almost all of them do that. It won't be a problem for me since the MoBo I'm buying has 4 slots so the overhang won't keep me from using the other 2 open slots.
This thing comes with 2 120mm x 25mm fans rated at 101.6 CFM @ 2500 rpm
I think that 106 CFM is combined for both fans... If not; I guess I would just point them downwards and make a Xigmatek hovercraft
The one thing that I don't like is that the fans come with a RPM control POT for fan speed control --- 3 Pin connector. Don't really like this as I'd prefer PWM Fans going to the CPU Fan Header on the MoBo --- 4 pin connection.
Oh and according to the Thermaltake site those fans are rated at 6W max consumption each.
My questions:
1. What is the power rating of the CPU Fan Header on that MoBo? I checked the MSI website; downloaded the MoBo manual and there is no mention anywhere of the power rating of that header.
2. Let's say I get the TT Frio; and the CPU Fan header can handle the load.... Could I connect those two fans to it with a 4-pin to 3-pin Y adapter? And would they allow for PWM? I read somewhere that you can do PWM on 3 wire fans too, but not sure.
The TT Frio is about U$60.00 from the Egg and includes the 2 fans.
For that money I could buy a TR Ultra 120 Extreme Rev C (CrazyPC), but I'd need to get fan(s) separately. I was thinking one of these: http://www.crazypc.com/products/afc1212d-58170.html
And since it is PWM there would be no problem in controlling it from the BIOS.
3. That delta is rated at 9.6W max power draw... Is the CPU Fan Header on the MoBo just going to start crying if the fan goes up to 100% speed?
Ok guys... I await your responses.
Thanks
Sebastian
I'll get:
- Delta Fan
CPU: Phenom 2 555BE
MoBo: MSI 870 - G45
My questions:
Thanks
Sebastian
