marzipanius
- Jan 24, 2014
I'm running a fairly warm loop, at around 60C (140F), with clear DangerDen tubing made of PVC. Nothing but distilled water in the loop, and all components are copper. I understand that tubing becoming foggy is natural as plasticizers leak out when the plastics are heated up, but the yellowing is worrying me.
Looking into the plexiglas reservoir shows crystal clear water with no discoloring, and no film or coating inside the reservoir either. I keep my radiator mounted external to the case, so part of the tubing is exposed to indirect UV, and the other half of the tubing sits inside the case - no visible difference in discoloring between outside/inside, and since PVC is UV resistant I suppose this makes no difference what so ever.
I haven't detached any tubing yet to see if the yellowing is a film or if it's contained within the plastic itself. I did not do a "vinegar flush" the first time, but i did a several hours long normal distilled flush during my initial setup.
Any ideas?
Any ideas?
