- Feb 16, 2008
- East Coast
It is the amount of DEHP/phthalate plasticizer (water soluble) that causes the rapid discoloration and inner bore buildup, if temp water is warmer from constant cpu or gpu load, it happen quicker. There are hundreds of pics just like yours all over net for 10 years.
Like others have mentioned primochill advanced LRT is DEHP/phthalate free and wont do that. But it is primarily a cosmetic issues. 10 years ago most used tygon 3603 tubing, and within weeks to months (depending on computer use/water temps) it was always cloudy. It isnt gpu blocks that usually get plasticizer buildup, it is the impingement plate and tiny pins of cpu waterblock that usually get some buildup.
As to whether the plasticizer leach causes the tubing to be white, yellow or green depends on tubing. Tygon tends to be white at first then yellows, xspc tubing green, etc.
Here is my tygon 3603 tubing in 2007 with plasticizer buildup, looks whitish at first, then slightly yellows over time (as you can see aesthetics were not "in" back then). And back then everyones tubes looked that way. And it effects cpu temps about 0.5C after about 1 year from plasticizer in cpu pins, ie cosmetic. Option 1 leave it alone, option 2 change out tubing, even if you clean it it will come back to some degree.
Here is the same setup 8 weeks earlier, freshly built.
