storm-chaser
Disabled
- Sep 2, 2011
- Upstate NY
I've been tinkering a little bit with my Hexacore Phenom II rig. Finding AMD Overdrive to be very fun in terms of getting the most out of my overclock.
Only thing lacking is the ability to increase CPU-NB speed. If you disable a custom P state in the BIOS CPU NB speed will default to 2000mhz, but then I can set custom turbo settings like this:
-We are working with an AMD 960T processor. This CPU is unlocked to a hexacore that is stable 3.8Ghz across all six cores. Using the turbo functionality I was able to set my first 4 cores to 4Ghz turbo and the last two cores to 3.8Ghz turbo. This gives me the best of both worlds; I get the stability I need while turboing up to 4Ghz as needed for the 4 good cores.
