- Aug 27, 2004
ok, i was told to download two programs to tell me what i can upgrade and what can help me tweak my system to get the best performence. Here are the results on both Sandra and CPU-Z...
Name AMD Athlon
Code Name Thunderbird
Specification AMD Athlon(tm) Processor
Family / Model / Stepping 6 4 2
Extended Family / Model 7 4
Package Socket A
Core Stepping A4
Technology 0.18 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!
CPU Clock Speed 1202.1 MHz
Clock multiplier x 12.0
Front Side Bus Frequency 100.2 MHz
Bus Speed 200.3 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1202.1 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic no
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer Compaq
Motherboard model 062Ch, None
BIOS vendor Compaq
BIOS revision 786K1
BIOS release date 02/16/2001
Chipset VIA Apollo Pro rev. 3
Southbridge VIA VT82C686 rev. 22
Graphic Interface AGP
AGP Status enabled, rev. 2.0
AGP Data Transfert Rate 4x
AGP Max Rate 4x
AGP Side Band Addressing supported, not enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type SDRAM
DRAM Size 128 MBytes
DRAM Interleave 4-way
CAS# Latency 2.0 clocks
RAS# to CAS# 2 clocks
RAS# Precharge 2 clocks
Cycle Time (TRAS) 5 clocks
# of memory modules 1
Module 0 Micron Technology SDRAM PC125 - 128 MBytes
Software
Windows version Microsoft Windows Meunknown
DirectX version 9.0
Can anyone please tell me what kind of tweaks i can do that will not ruin my computer, but make it go faster...
Thanks,
Matt
CPU-Z
Number of CPUs 1Name AMD Athlon
Package Socket A
Core Stepping A4
Technology 0.18 µ
Bus Speed 200.3 MHz
L2 Location On Chip
BIOS vendor Compaq
BIOS revision 786K1
AGP Max Rate 4x
Memory
DRAM Type SDRAM
Software
DirectX version 9.0
Thanks,
Matt
