- Aug 13, 2001
- Deep Blue Sea (Maryland)
Morpheus: how to cach SEIT so i don't have to download and upload a single WU everytime??
btw, i do use SETI Driver.......
LandShark said:oh, nevermind! got it. just change the cache value from 1 to whatever i'd like, rite?! but tks for ur idea!!
however, i wonder how come the WU time varies quite a bit?? on my PIII 1.0G machine, idling, nothing running, using CLC + SETI Driver + SETISpy. using it shows like high-1xxMFlop/sec, but sometimes, like this morning, it shows the machine is "only" doing 70-60MFlop/sec!! i'm sure nobody used the computer over nite, it's just sitting idle all nite!! how come??? any idea???
will it b/c the memory allocation stuffs?? but there's really nothing running, even at the background. will a re-boot help?? btw, i did defrag the hard drive. or b/c of the "av #"?? those 0.4xx number under SETISpy. what's going on??
Morpheus said:& I'll keep a spot warm for you in the top 25.... Daman...
LandShark said:i did turn off any power management both in BIOS and Window. the only isn't set always on if the monitor which i set to turn off after 15mins of un-use.
i've heard u guys saying average time xxhr at av.=0.4xx. what's that?? will the WU's av. affect the time?? i've seen they ranging from 0.04 to 0.6x. which will give u less work out, less time to finish? if i saw a hard WU, could i delete it manually and get a new one?? if so, which file should i look for?
btw, that SETIDriver caching feature really helps!! now i can have all of my machine running STI 24/7 instead of only one of them running 24/7, and the rest doing only 2 per day.
tks again for u guys' help!!!
keep on crunching and aiming for the top 100 spot.
LandShark said:and for the spirit of science, i don't think i should delete any "tough" WU just b/c to rank up faster.
Glad to here that, let me tell you. I almost mentioned it...then thought better of it. Didn't want to seem discouraging or anything.
