icrum@MythTVBackend:~$ sudo apt-get install linux-`uname -r`
[sudo] password for icrum:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package linux-2.6.24-16-generic
yea but doing that way you are limited to the drivers that in the repos. what happens when you want a driver thats beta? or supports cuda? or you just want the latest drivers? you have to manually install it.
sure i can just check "use restricted drivers" in ubuntu, but that only gets me 169.08 drivers. i can install envy, but that only gets me 173.14 drivers. i wanted the 177.73 beta driver, its the latest driver with cuda support, for GPU folding
Can't you just add a repository that includes those packages?
I believe Envy allows you to point the program at the newest drivers via the "manual" install, however I could be wrong
i wouldnt really know how to do that since the package is just in the form of a .run file on nvidias website.Can't you just add a repository that includes those packages?
[i] x11-drivers/nvidia-drivers
Available versions: 71.86.06 96.43.07 100.14.09 ~100.14.11 100.14.19 [M]~100.14.23 ~169.07 ~169.09 169.09-r1 ~169.12 [M]~173.08 ~173.14.05 173.14.09 ~173.14.12 [M]~177.13 [M]~177.67 [M]~177.68 [M]~177.70 ~177.80 {acpi custom-cflags gtk kernel_linux multilib}
Installed versions: 173.14.09(03:01:47 10/25/08)(gtk kernel_linux multilib -acpi -custom-cflags)
Homepage: http://www.nvidia.com/
Description: NVIDIA X11 driver and GLX libraries
