- Feb 14, 2003
i wouldnt really know how to do that since the package is just in the form of a .run file on nvidias website.
Well, Ubuntu is a Debian derivative, and it uses apt as a package manager. apt can install anything that it has listed in its repositories. You can select whether to enable the stable (default), testing, or unstable branches, which allow you to access more packages, but with more likelihood of bugs. You just have to point apt to the right repositories.
Portage is a bit different. There is only really one major repository, and while it tells you which packages are stable and which are testing, you can install whichever you wish. Also, they basically just download the nvidia driver scripts from the nvidia site to the Gentoo mirrors and then modify them slightly and write ebuilds for them so that they work automagically for Gentoo users.
I've often maintained that while Gentoo is a hard distro to install, it's a really easy distro to use day to day.
