Zone15
- Dec 30, 2012
After moving my build into my new P280 case, I was doing some tests and noticed the temps on my Megahalems seem a little high. The temps were pretty much the same in my Antec 902 but I assumed maybe they were a little bit high because I needed to clean the heatsink of some dust. Now here it is, dust free and it's still a little high to my liking.
I've got a Noctua NF-F12 PWM fan on the Megahalems as a push fan. I've tried adding a pull fan to it in the past and no matter what the fan it seems they all like to whine when pulling, so I've stuck to the one NF-F12. I've got my 2500K OC'd to 4.4 GHz @ 1.26v (under load it fluctuates between 1.256-264v).
The ambient temperature in the room was 65F/18C at the time of the test. I recorded the lowest temps at idle and then ran Prime95 blend for 15 minutes and recorded the highest temps.
IDLE(*C):
25 / 24 / 28 / 23
LOAD(*C):
53 / 55 / 57 / 53
I ran the test again with the current ambient temperature of 70F/21C and got these results:
IDLE(*C):
27 / 28 / 31 / 26
LOAD(*C):
57 / 60 / 61 / 57
Do these temps seem high to anyone else or am I just over-reacting? Is this still in the normal range? Is this still a safe temperature? This test was done at 70F which is usually within a degree of the warmest this room gets.
I don't know if maybe it's not mounted great or what. I originally used the TIM that came with the Megahalems, the Prolimatech PK-2.
IDLE(*C):
25 / 24 / 28 / 23
LOAD(*C):
53 / 55 / 57 / 53
IDLE(*C):
27 / 28 / 31 / 26
LOAD(*C):
57 / 60 / 61 / 57
