- Dec 6, 2013
- Baden, Austria
Hi,
for casual usage I usually have my CPU clocked to 2400MHz, HT disabled, everything else set to auto. Recently I undervolted the CPU just for the fun of it. I set offset to "-" and worked it down to -100mV running at ~0,9V. It worked fine. I thought that undervolting is good due to energy saving, better thermals, etc. I opened my pc case to work on my cabeling and accidentaly touched the VRM heatspreader of my P8Z68-V Pro Gen3 (it also has an array of VRM mosfets on the backside of the mobo). It was extremely hot on both sides. No more than 2 sec contact possible. I reset the voltage and VRM thermals are normal again. Is this a known issue or are the undervolters ignoring VRM thermals? The only reason that came to my mind was an increased swichting frequency of the VRMs due to low voltage that could have caused that issue.
Any ideas, comments?
Cheers,
Chris
Hardware: i7 2600K, Bequiet Shadow Rock TopFlow SR1, P8Z68-V Pro Gen3, 4x2GB Kingston Value RAM 1333MHz, Corsair TX850W, Samsung 840 EVO
Cheers,
Chris
