Roflpancake
- Nov 28, 2013
I'm new to this site and new to unlocking CPU's and OCing them.
I had an AMD Athlon II X3 455 Rana that I unlocked to a AMD Phenom II X4 B55.
My idle temps were aprox. 50c after I unlocked the CPU, I did not check idle temps before this. I am currently in the process of running Prime95 to check for stability. It's been running just over an hour and my CPU temps shot up to about 70c (Max 72 Low 69). I've rebooted my computer a couple of times before to make sure I don't get any boot issues after unlocking the 4th core.
So my questions: Is the temp too high to leave the 4th core unlocked without a water cooling system? If I do get a watercooling system will I be able to overclock my CPU while it's unlocked without frying everything? Also, is it bad that this new unlocked "Phenom B55" requires 126W of power and my motherboard only supports 125W CPU (lol)? It was originally a 95W CPU before I unlocked it, I believe.
