Going for an hour now at 4411...as usual I have a high VID, but as usual I've got pretty high clocks.
Air with Tuniq Tower and eVGA 790i, a week 805.
I dunno how accurate the temp is supposed to be, can anyone comment? It's spiked to 83C on a couple of occasions.
first off, as others have said...
1.54v, what are you thinking... oh, okay, we've been down that road
Props for having the cojones to push to 1.54v to achieve 4.5GHz though!
As for your temps, its been my impression that the TJMax for these chips is actually 95C, not the 105C that CoreTemp uses. Since these programs calculate your "actual" temp as just a function of how far you are from the TJMax, CoreTemp gives you 10C higher than it
probably is. That said, you can subtract 10C from your Coretemp, or just use Realtemp, which has the 95C adjusted TJMax for the 45nm chips.
Also, its been my understanding that one should absolutely never hit or go over 20C under TJMax. Since its 95C for these chips, and your adjusted spike puts you at 73C, you
might want to lower your VID; if not for temp damage, then for electromigration. Have a heart and love your E8X00... stop the torture now!
PS - You're crazy!!! I'm afraid to go over 1.4v, and thats been with temps no higher than 65C!
