J jsmcbn New Member Joined Aug 14, 2004 Location chicago Oct 22, 2005 #1 I have Unrealtournament 2004 but the Play disk is damaged beyond repair can anyone help me?
ninthebin Member Joined Mar 24, 2002 Location Liverpool, UK Oct 22, 2005 #2 if its installed - you dont need it, one of the patches removed its reliance on having a cd. If its not installed, contact the publisher and they will send you which ever disc you need for a small fee
shard Member Joined Sep 10, 2003 Location You Should Make a Wish! Oct 22, 2005 #3 Yeah, if I recall correctly, its the 3383 patch that fixed it, so go DL it!
WingsofGOD Member Joined Apr 16, 2005 Oct 23, 2005 #4 google is also your friend, ut2004 and nocd come up with something that would work for you.
9 9mmCensor Disabled Joined Oct 23, 2003 Location Banned Camp Oct 23, 2005 #5 WingsofGOD said: google is also your friend, ut2004 and nocd come up with something that would work for you. Click to expand... There is no need for a crack. The patch takes care of it and is dev supported.
TheGreySpectre Member Joined Sep 6, 2003 Oct 23, 2005 #6 and no crack discussion on the forums Just go download the patch
