Please read my explanation more carefully. The older cores only use one thread per gpu. The newer core_21 v17 is multi thread for the sanity check. In other words, the gpu can continue calculations fully occupying a thread and use additional thread for the sanity check. The older core can only use a single thread, so gpu calc is idle while the check is performed, which is why the load drops on the gpu every so often. If all the CPU threads are busy when the new core does the sanity check, something is going to be interrupted, either the smp or the gpu, not sure which. With the 980ti, you do not want anything to interfere with the gpu calc. Best to leave an extra core or 2 available for the GPUs to ensure no contention delays. Not sure which folding process, gpu or cpu, will take priority for the sanity check if no idle thread available. Smp does not like being interrupted either, so possible smp10 with thread contention may be slower than smp8. If you decide to perform some testing, be sure the comparisons are with same wu running on each device.
