- May 14, 2012
- aldershot hants uk
hi chaps, just a update on my o/cing, well running at 4.4 and all is good,had no issues with the computer at all with the o/c , just up graded my top exhaust 230 mm fan ,for 2 Aerocool Dead Silence 140 mm Red fans, wow what a difference , drop the temps by 5 degrees, fan set up is as follows, 2 Aerocool Dead Silence 140 mm Red top draw, 1 Aerocool Dead Silence 140 mm Red front draw. 1 Aerocool Dead Silence 140 mm Red rear exhaust. and a Aerocool 200 mm front draw,. so i,m looking for a new 200 mm for the front draw as its the loudest of them all .played far cry 4 for 6 hrs, and cpu temp was 38 degrees. idle has now gone down to 24 degrees, room temp is 20 degrees. the temps before the fan change was idle 26 -28, and cpu was 43, note: new idle temps are with all fans at half speed, apart from the middle fan in the cooler, that runs at full speed, only use full speed when gaming, so i,m really happy with these temps, cpu voltage is 1.336, @ 4.4 ghz, i ran prime 95 for 2 hrs and the temp were max 48 degrees, so all in all good cooling, i have o/cd the ram to 1760 mhz, not o/cd the graphic cards,as im happy with the games no issues with stuttering. i would post pic but cant get my head around it, oh and the case looks nice with the red led,s and the formula v black and red and the dark rock pro 3 is the ducks nuts, p,s those Aerocool Dead Silence 14 mm are great fans and quiet max of 19 db flat out and 10 ish on half speed, and the shift the air as well , i would recommend them
also i wanted to ask, do i need to plug in the 4pin power supply on the m/b, or id the 24 pin one enough ,thanks .
