Hi All,
Just looking for some advice on upgrading my system. I'm wondering if I should upgrade the CPU or GPU or maybe wait to build a new one. If I could get another year or so out of this by upgrading I would do that. At the moment I can run most games on high without problems but want to be able to do the same for the coming year. Also, are the g-sync monitors worth the money to upgrade to? My Specs are as follows:
MB-Asus P8P67 Deluxe
CPU-intel i7-2600k
GPU-Asus GTX 670
SSD-OCZ 250GB
HD-WD Caviar Black 1TB
RAM-16GB
Any suggestions on which CPU or GPU to upgrade to would be helpful. I can probably spend about $500 so if both need upgrading I would wait until I can do a new build. Thanks for any help.
CPU-intel i7-2600k
GPU-Asus GTX 670
SSD-OCZ 250GB
RAM-16GB
