I am looking to upgrade my sig rig. Budget is $800-1000 CAD. Not enough for a full system so I was looking at 5900X or 5800X3D along with 16 or 32GB of RAM to go along with it. Hoping the upgrade will get me another 3-4 years.
I would wait 1-2 months as the new AMD will be released soon. X670E motherboards are already listed on most vendor sites. I think you don't need a 12-core CPU while the new 8-cores will be probably cheaper than the 5900X/5800X3D ... but you will need to spend additional money for the motherboard. Good 32GB DDR4 will cost you not so significantly less than 32GB ~DDR5-6000.
Think that the current AMD generation is already on the market for 2-3 years. If you want it to live some more, then I would still wait and get a 2nd hand 5900X/5950X as I bet that many people will sell them for half price in 2-3 months.
Buy G.SKILL Trident Z Neo (For AMD Ryzen) Series 32GB (2 x 16GB) 288-Pin RGB PC RAM DDR4 3600 (PC4 28800) Desktop Memory Model F4-3600C16D-32GTZNC with fast shipping and top-rated customer service. Once you know, you Newegg!
You'll be good for a while and hopefully have an easy upgrade path as DDR5 RAM & CPUs improve. Not to mention the PCIe gen 5 for a new NVME once they become a thing.
First PCIe 5.0 SSDs can be a bit disappointing. I mean higher sequential performance but not really higher random ... so about the same as you see now when you set RAID0 on 2 PCIe 4.0 SSD. There was also news about higher temps. At least, this is what we could see from the early manufacturer "leaks". I would wait a bit or just read some more before purchasing.
These new AMD are somehow satisfying. They are not really beating Intel, but still feel better.
