So the i9's are gonna be using the 1366 socket?
I'm thinking of doing this to. I might be upgrading my PC in Feb. 2010 to Intel. We'll see.
Same Socket does not automatically mean the current i7 MoBo's will support i9. There is a good chance it might since the memory controller is integrated into the CPU, but I'd still have my doubts that early 1366 MoBo's would actually support i9.
Pop in a Q9550 for ~$200 and be done with it for a good 4-6 Months
I get your point of view but why try that hard to convince me not to get an i7 when others ppl do recommend it if i have the cash for it I still didnt order i'm still overlooking the option for the Q9550
If some girl asks to check the internet on your pc, she will never say "wow, this is fast. Killer ssd setup you have going and insane overclocked processor. It really makes surfing the net a snap", but she will say "geez man, insane screen. Nice!" (hopefully followed by "lets make out")
You stick with it because you already have it. Its not like you're near the top of the lga 775 lineup already. You're way on the bottom, almost 3 generations back. LGA to someone in your position, is very much alive especially when all he needs to do is drop in one part and especially when prices are so good.
The difference is, first, that a Q6600 generally wont be able to run 4Ghz 24/7. Its sweet spot is 3.4-3.6Ghz. That couple with the fact that aside from gaming the i7 920 hands the Q6600 its lunch in all other benches tells me I would see a difference. Especially in anything that is multi threaded.No. What doesn't make sense is the arbitrary distinction people make depending on how the question is asked. If someone like me who's running a 4ghz quad asks if I should make the leap to the next gen cpus, I assure you the response will be no , that overall there is no difference between jumping from a 4ghz quad to a i7-920 chip. But if someone asks if they should go from a e6600 to a i7 920, there's suddenly a magical difference between going to the 4ghz quad vs the i7 920 setup.
I dunno about you, but I passed math and I learned some little tricks called addition, subtraction, and most importantly of all the meaning of the equal sign. Once you're at the point of the 4ghz quad, there is no difference in either being 4ghz quad or going i7 920. All thats left is to weigh the costs of jumping from your current platform to either the 4ghz quad or the i7 920.
So again: drop in upgrade- 159 dollars
i7 platform- 200 for chip, 200 for board, 100 for ram, 60 for heatsink.
As far as your math, ok, fine. Here is something to consider...If one does go i7, he can sell his old mobo, ram, and CPU to offset the cost significantly. Sure its going to be more than a drop in, but its up the the OP if he wants to spend that money. Its our job to show him the positives and negatives of making/not making the move.
"So again" we know your opinion, but it may not be the best for everyone or the OP in this case.
Agreed! +1Get a X58 + I7.
Upgrade GPU later for the DX11 when they are a lil cheaper and Nvidia show us what they have.
Agreed! +1
EDIT: Didnt read your last post...
Just make sure the bios version you have supports 45nm quads with P35 chipset.
