- Feb 17, 2011
- Glasgow, Scotland
Hi. With help from this forum I sorted regular blue screens - overclocking - voltage mis-match.
Anyway, .. I have
Giga Byte P67A-UD5 socket 1155 motherboard bought end january2011 and fitted with intel i7 2600 sandybridge now overclocked at about 4.2 (down from the 4.9)
2 Radeon XFX HD5770 graphics cards with link
8mb RAM
Corsair 70 liquid cooler
G7 Power Extreme 780W power unit
Windows 7 x64
Viewsonic widescreen screen (24" ?)
DVD RW
2 hard discs Seagate Barracuda 7200 both 750GB and both about 3 years old.
The hard discs are about the only things left untouched, altho I changed from Windows XP Pro to Windows 7 x 64.. losing 6 months worth of Outlook emails as the back ups failed - another story.
I am looking to send the boot up hard disc away to see if the emails can be recovered - they were backed up onto a WD 1TB Book in FAT file but that backup using Smart Email backup failed due to the size of the files. Otherwise its been ok for document backups.
Sorry about all the verbal!
Anyway, what I'm thinking is to keep 1 hard drive in the tower as backup along with the external disc drive; and send the main hard disc away to see if my emails can be recovered. As both hard discs are 3 years old and I use the machine a lot for research with multiple browser tabs open at any one time, I'm looking at fitting a new main hard drive - so what do I go for??
The boot up just now is slowish. Should I use a large SDD for the OS? I use Microsoft Office mainly and get 300+ emails a day as I help run 3 charities. Or should I stick with more conventional hard drives?
I intend keeping the main hard drive and perhaps use it in a back up machine. As you know, the motherboard has some issues re the sockets so I'm kind of limited to the 2 6(gb?) sockets for the drive connections.
Budget ? Willing to spend up to maybe £400 or so as the hassle of not having a robust main machine causes me big probs if things go wrong.
I've only had the machine up running for 4 weeks since the upgrade so can easily back up files and reload onto a new boot disc from the CD?DVDs
Reason for the upgrade was that the old MSI motherboard and quad core and the graphics cards were overheating a bit and getting noisy.
cheers for any ideas/suggestions
Ian frae Scotland
Anyway, .. I have
8mb RAM
Windows 7 x64
DVD RW
Ian frae Scotland
