- Sep 14, 2004
- Jensen Beach
I'm not sure where to post this to get the best results, but here goes...
I've been experiencing some really odd problems after I upgraded my ram and hard drive yesterday evening. I setup a WD Raptor as my OS and cache drive, and went from value 2x512 to tight 2x1gb.
Let me start by running through what I did...
I moved my original hard drive (seagate) over to sata 2 (slave) and put the new hard drive (raptor) into it's place in sata 1 (master). I set it to boot from CD and put the Windows XP SP2 disc in the drive, booted it up fine, detected both the ram in 1&3 dual channel and the raptor in sata 1. The windows CD booted up and I used that to partition the raptor, to it's maximum capacity. After that completed windows installed fine, and restarted.
The raptor booted up windows, so I started to install my software. After 30 mins of this I find out that the raptor is not drive C:/, it is infact drive G:/ - I must of missed that when partitioning it, I also am not sure if I installed those programs on drive C:/ which was the original seagate drive. The reason I notice this is because things started to go weird, the start menu paused when I hovered over it, graphic artifacts apeared all over, the mouse locked up, the screen when back, and then it came back on seconds later all apeared to be back to normal... so I figured the 2 OSes are causing a conflict.
I shut down, took out the seagate and just booted up with the raptor, it crashed 3 times on loading windows, but 4th time it loaded fine? I figured I needed to get on the internet to find out about my problems so I shut down again, take the raptor out, and put just the seagate it. I get the same 3 crash problems and 4th it loads, now it seems both OSes are corrupt.
I shut down yet again, take out the seagate, put the raptor in, boot from windows CD, format and partition the raptor again, this time to drive C:/ as it's the only one in the computer. Procede to install windows on it again and half way through 'transfering files' it brings up an error, so I restart yet again.
Tried again with the install and it got past that part and onto the actual installation, half way into this it tells me D:/386 cannot be found on the Windows CD, and asks me if I want to skip it, I tried not skipping but it wouldn't work, so I continued without it, it poped up a few more times during the install saying that dir didn't exist. - Clearly though it installed right the first time with no errors, why is it giving me all these this time around?
So anyway I finish up the install, boot up windows successfully, and start to install drivers such as the graphic card. Once installed I restart, loads up fine, all looks pretty, and shortly after it locks up yet again, screen goes black, and then comes back on, which black artifacts in the windows I had opened, this seems to happen when I tried doing opening multiple dirs at once.
I am now currently in this state, it keeps happening on and off, and the long pauses with the hard drive are telling me something is wrong with the raptor. The artifacts are telling me something is wrong with the gfx card, and the crashed tell me somethings wrong with the windows installation. I'm pretty much at a loss, this must all be connected, but what too? Easy answer would be the OS installation, but why would that install correctly the first time, but not the second time around?
Any help or experience is much appreciated
- Dan
- Dan
