StevieP2515
- Dec 3, 2017
Hi all, I'm looking for advice on which graphics card to go for. I'll explain my situation first so you can see where I'm at and give me your advice and it will be appreciated if you take the time.
I have two boys who have pcs they play on. I'm looking to upgrade one of them and in turn upgrade both. Firstly the pcs are both quite old. Youngest son has an i5 750 with 8gb ram and a 7950 gpu. He basically plays Roblox and Minecraft on it. The eldest has an i5 4460 16gb ram and a gtx 970 and he plays r6s, pubg, ark survival evolved and those type of more demanding games. I also have a a spare i5 2500k with motherboard and ram. So I'm looking to put the gtx 970 with the i5 2500k and 8 GB ram for my youngest. Then use the 4460 16gb ram and whatever card I buy.
Now onto the cards. I was set on getting a rx580 but the gains wouldn't be that big. So I have looked at the rx590 but then my head was turned by getting a second hand gtx 980 ti. It's about the same price. The problem being there are so many options out there especially if you look at the second hand market and by going up £20-30 each time you have too much to choose from. I wanted to spend about £150 ISH.
So would it be better to get the much newer rx590 over the gtx 980 ti because of amd driver updates or is there another option you would recommend? I will look next year to upgrade the cpu and motherboard so that's not a concern right now for me.
Thanks for reading and any advice would be most appreciated.
