Hello.
To start briefly my sys specs are :
gigabyte ud3h b3 mobo , 2600k * stock speed , 8g kingston hyperx ddr3 , 128gb crucial m4.
As of today Ive been experiencing the following problem.The problem happened to occur when I was browsing the web at all times but I am not convinced that it was the relevant factor to this situation:
As I was browsing , the system dwells up (mouse still moves but with a busy cursor and the browser and task bar are unresposnive).The Hard drive activity light also goes on and stays on when this happens.
Then when I try to press crlt alt del to start the task manager it is unresponsive at first (and sometimes the screen turns black with the cursor still there) it gives me the "The logon process was unable to display security and logon options when CTRL+ALT+DELETE was pressed. If the operating system does not resp.."
popup. THEN IT RETURNS TO DESKTOP WHICH IS STILL UNRESPONSIVE.
Then either a random BSOD comes about OR application error messages such as this :
http://imageshack.us/photo/my-images/195/img2013041800051.jpg
Or with other random processes come about and most Icons start to dissapear off the desktop and taskbar (as though someone had deleted them).
THEN a random BSOD involving random processes , usually core windows processes such as this :
http://imageshack.us/photo/my-images/40/img2013041800049.jpg
This happens after about an hour of usage of the computer and has happened several times today already.
I will post my thread now and provide further information you could need to help me.
What could this problem be?
Thanks.
Thanks.
