- Apr 14, 2002
- missouri city, tx
i know that space probes use decaying plutonium to generate heat, which by means of thermocouples is used to power the space craft. how huch power do thermocouples put out? if its a substancial amount, coulnt we use them to absorb cpu heat, thus cooling the cpu, adn disposinf of the heat, rather than moving it? casue with a total power output of 475 watts, using as pelt, that will notiable rais ones rom temperature, which raises core temperature. but if we absorbe teh energy, then it wouldnt heat the room. what one does with the absorbed eneregy i dont know.
or is thjere another way of doing away with heat, not just moving it? i know that you cant destroy energy.
it would be easier to move the absorbed energy outside with wires, and put the wires on a heating element.
