- Jun 18, 2011
So right now I'm kinda stuck between the two, any advice? the frio is a bit better, but the v6 gt is about 10 bucks cheaper (fry's, about a 6-10 minute drive) and looks way cooler...
The one question I have the would let me decide is how wide teh frio is, including the fans and everything. I'm worried about my ram ( corsair vengeance, ik the v6 will overhang the first slot and not clear it, but I'm not sure if teh frio will not.) I only have 2 ram sticks so I can do 2 and 4 but the I can't upgrade in teh future unless I replace the existing ram and buy new ram.
There is about a 51.5mm distance from the center of the socket to the first dimm slot on my motherboard, the z68 extreme4 from ASrock. So if they are both going to reach teh first slot then I will go with the v6 gt, and if the frio won't reach first slot I'll get that. So does the frio reach the slot?
Also, I will be using this to cool an i5 2500k, and what kind of stable overclocks can I expect from the 2 coolers?
