- Jan 12, 2005
- UKbiquitous
I'm got an Akasa AK-913 (http://www.sww.nl/product_images\product_-1694711907.jpg) and I was thinking I might like to put a Vantec Tornado fan on it instead of the current Akasa one.
However, I had a couple of questions about the whole affair first:
1. The current Akasa fan on there is 25mm thick. The Tornado is 38mm thick. The current fan is attached by some bolts that came with the heatsink. Would I need a new set of bolts to connect it? Or would I have to find a workaround for it? Basically how can I fit the Tornado onto the heatsink.
2. The Akasa fan comes through a speed controller which came with the heatsink situated in a PCI slot. Would it be possible to run the Tornado through this speed controller? I know Tornados need a speed controller, so would this one do? It is powered by a 4 pin molex, not off the motherboard.
Any info you could give me would be very helpful, thanks.
