Hey all. So I consider myself to be about a 7/10 in knowledge of PC's and how they work, still learning, still reading. Recently I found myself wondering about VCORE voltages. I know the FX series chips are generally safe to overvolt to 1.5 - 1.55 volts, but can they be run higher? The reason I ask, is because (by error only) I found myself pushing 1.57-1.6 volts on my chip not to long ago when setting up my overclock, and my load temperatures, albeit pushing the limits, were still relatively acceptable. They were around 57-60 on the chip and 65-68 on the socket at that voltage. I'm not sure if I just got lucky with my cooling or the hardware itself, but I didn't consider that to be an outright "unacceptable" load temperature range, though I do recognize that it is quite high and nearing the limits. So can these chips run at voltages that high and have a reasonable amount of longevity, provided the cooling is adequate? Or will the chip suffer catastrophic failure at such high voltages?
TL;DR: Can you push higher volts than 1.55 provided the cooling keeps the temps below the thermal margin?
