- May 22, 2011
- USA
I found this out of the blue and thought I'd share this for those who are looking to add a fan controller that has a LCD built into it for a Very affordable price.
Product - Enlight EN5601500 ComboSpy Smart Fan Controller -
Technical Specifications:
Power Source
Standard 4-Pin connector of PC's power
Display
Built- in LCD display
Number of Temperature Sensor
2 Sensors
Monitoring Temperature Range
0 ºC - 90 º C ( 32 º F - 194 º F )
Maximum Number of Fans
4 Fans
Monitoring Fan Speed Range 0 - 9999 RPM (for safety reason fan is never turned off completely)
Maximum Fan Power
1000mA (1 Amp) or 12 Watts Per Fan Connector
Dimension ( W X H X D )
5.9" X 1.6" X 6.1" ( 150mm X 41mm X 155mm )
Power Source
Display
2 Sensors
4 Fans
Maximum Fan Power
