Iormungand
- Jun 24, 2014
I am planning out a custom case build, and while looking into a open loop cooling system for it, while brainstorming with a friend of mine, we came up with the idea of trying to use a transmission cooler as the radiator for the case.
Something like this for example
http://www.jegs.com/i/JEGS-Performance-Products/555/60373/10002/-1?parentProductId=1032939
This model, and most models just use normal sized barbed fittings for tubing, this one being 3/8 inch ID.
I have pretty limited experience with open looped cooling systems, but can someone with more experience weigh in as to whether this would be viable? Or if there would be any issues with it. My plan would be to get a rather large one and have either a 200mm on each side, or an array of 2x2 120mm fans depending on the size of the radiator.
If they would be viable, other than having to create your own mounting system, a lot of them would appear to be a pretty good value for PC water cooling.
