- Dec 8, 2002
Ok, so I have a Thor V2 case, Ryzen 1700x, Crosshair VI Hero, and a XFX Vega 64, on the CPU I have an Eisbaer 280, and a Eiswolf 120 on the Vega connected together, GPU runs at 1653 HBM 1020, load temps top out around mid to high 40's.
Nothing fancy, but gets the job done...heh
When ideling all is good, cpu is 25°C GPU is 23°C, under load say GTA 5, GPU goes to mid to high 40's the water heats up, and the fans start to vibrate which resonates through the entire case,
I can press on the back, top, side and it quiets, let it go and it starts to resonate again, if I touch the fan hub it stops, let it go and in a little bit it starts up again, shut down the game or bench app and once the rads cool down the vibration goes away.
I am using the fans that came with it, going to get some new ones, but for right now, any Ideas why it would vibrate like that???
The 280 rad is mounted to the top and the fans are pulling through from the outside, the 120 is mounted to the back, with fans in a push/pull venting out the back...
