Video Locks up, out of ideas! Desperate help needed.
PolishPaul
Hello guys and gals,
I bought a PC from a friend and i'm having some video issues (i think).
I'm not new to hardware and computers so i have a good idea of what's going on. Having said that, i'm stumped! :bang head
I've installed windows, patched it, installed all newest mobo and peripheral drivers available.
When i play games (old or new) on this machine, it will eventually lock up; this happens after you get warmed up in the game for a while (10 min+ depending on game). First i notice few graphic glitches blink here and there. Then the pc freezes up for about a minute with the sound still on. The sound stops, and about 10 seconds later it un-freezes. Once this happens everything is screwy. If i continue to play it will keep freezing up frequently (every 1-2 min). If i exit the game and try again, nothing really works, some games won't load. Games tried so far - OpFlash, Simcity4, BF 2, Mechwarrior 4. All games experience the problem. Simcity has a smearing problem, not like the one mentioned above.
Another thing worth noting is that when i start the computer up for the first time, right at the beginning of POST i get this message "Your system is in safe mode, please disable any overclocking features" I tried resetting the BIOS to standard options to no avail...
I've reinstalled my vid and mobo drivers. Nothing...
I could really use some help on this one... I spent some good dough on this.
SYSTEM SUMMARY:
AMD Athlon 64 FX-53 Proc
MSI K8N Neo2 Platinum Motherboard
2GB OCZ Low Latency RAM
NVidia GeForce 6800 Ultra, 256MB
ViewSonic 20.1" LCD Monitor
Creative Labs Audigy Z2 Gamer
2x120 GB HD
650Watt PSU
DXDIAG
System Information
Time of this report: 9/8/2006, 18:16:36
Machine name: ZOIDBERG
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 FX-53 Processor, MMX, 3DNow, ~2.4GHz
Memory: 2048MB RAM
Page File: 153MB used, 3787MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6800 Ultra
Chip type: GeForce 6800 Ultra
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0040&SUBSYS_00000000&REV_A1
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: ViewSonic VP201b
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9147 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 8/11/2006 21:42:52, 4496128 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 8/11/2006 21:42:42, 3958496 bytes
Device Identifier: {D7B71E3E-4300-11CF-0B40-0A2000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0040
SubSys ID: 0x00000000
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Audigy 2 ZS Audio [9000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_20021102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.1164 (English)
WHQL Logo'd: n/a
Date and Size: 12/8/2005 11:55:46, 439296 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy 2 ZS DirectMusic Synthesizer [9000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy 2 ZS Audio [9000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Synth B [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Sw Synth [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Synth A [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS MIDI IO [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS MIDI IO [9000] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft SideWinder Precision 2
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0038
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x00E7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 02:08:42, 57600 bytes
| Driver: usbd.sys, 3/31/2003 08:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Vendor/Product ID: 0x046D, 0xC01D
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/4/2004 02:08:19, 36224 bytes
| | Driver: hidparse.sys, 8/4/2004 02:08:16, 24960 bytes
| | Driver: hid.dll, 8/4/2004 03:56:42, 20992 bytes
| | Driver: hidusb.sys, 3/31/2003 08:00:00, 9600 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 8/4/2004 01:58:32, 23040 bytes
| | | Driver: mouhid.sys, 3/31/2003 08:00:00, 12160 bytes
Gameport Devices
+ PCI standard PCI-to-PCI bridge
| Matching Device ID: pci\cc_0604
| Service: pci
| Driver: pci.sys, 8/4/2004 02:07:46, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00401102
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 02:08:21, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 02:14:36, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 01:58:32, 24576 bytes
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 01:58:34, 14848 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 04:01:07, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
MechWarrior Mercenaries (DX7) - Registry: OK, ExeFile: MW4Mercs.icd (50.06.0009.3002)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 98.9 GB
Total Space: 117.8 GB
File System: NTFS
Model: HDS722512VLSA80
Drive: D:
Drive: E:
Model: _NEC DVD_RW ND-3500AG
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 01:59:52, 49536 bytes
Drive: F:
System Devices
Name: D-Link DFE-530TX+ PCI Fast Ethernet Adapter (rev.F)
Device ID: PCI\VEN_1106&DEV_3106&SUBSYS_14061186&REV_86\4&3191A3E6&0&4870
Driver: C:\WINDOWS\system32\DRIVERS\dlkfet5b.sys, 3.46.0000.0431 (English), 7/1/2005 16:48:42, 43008 bytes
Driver: C:\WINDOWS\system32\vuins32.dll, 1.04.0000.0009 (English), 9/17/2004 17:37:42, 61440 bytes
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_086C0574&REV_46\4&3191A3E6&0&6070
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 02:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 02:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:58:29, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:58:29, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 09:46:40, 6400 bytes
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00401102&REV_04\4&3191A3E6&0&4170
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:21, 10624 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&3191A3E6&0&4270
Name: Creative SB Audigy 2 ZS (WDM)
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_20021102&REV_04\4&3191A3E6&0&4070
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 03:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 03:56:57, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 02:15:21, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 02:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 02:15:49, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 02:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 03:56:57, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:32, 501760 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:46, 439296 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:52, 114688 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:48, 7168 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:42, 142336 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:40, 77824 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:02, 754176 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:04, 154112 bytes
Driver: C:\WINDOWS\system32\drivers\haP17v2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:08, 179712 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 12/8/2005 12:20:14, 8192 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 12/8/2005 11:59:34, 293747 bytes
Driver: C:\WINDOWS\system32\ctstatic.dat, 12/8/2005 11:52:12, 313207 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 12/8/2005 11:52:12, 53932 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 12/8/2005 12:17:46, 33792 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:10, 87552 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:14, 536576 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:38, 548352 bytes
Driver: C:\WINDOWS\system32\cteapsfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:30, 157696 bytes
Driver: C:\WINDOWS\system32\ctemupia.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:58, 106496 bytes
Driver: C:\WINDOWS\system32\piaproxy.dll, 5.12.0001.1164 (English), 12/8/2005 11:54:34, 73728 bytes
Driver: C:\WINDOWS\system32\ctdproxy.dll, 5.12.0001.1164 (English), 12/8/2005 11:55:34, 71168 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 12/8/2005 11:54:46, 21504 bytes
Driver: C:\WINDOWS\system32\ctbas2w.dat, 12/8/2005 11:54:20, 140643 bytes
Driver: C:\WINDOWS\system32\ctsbas2w.dat, 12/8/2005 11:52:38, 265066 bytes
Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 12:42:28, 7406 bytes
Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 09:48:20, 1912 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0011 (English), 12/8/2005 12:23:16, 81920 bytes
Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.03.0000.0031 (English), 12/8/2005 12:23:16, 146432 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0467 (English), 11/10/2005 17:06:04, 340704 bytes
Name: NVIDIA nForce3 250 Serial ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_00EE&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&48
Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0446 (English), 6/3/2004 10:40:46, 79360 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 6/3/2004 10:40:48, 294400 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_00ED&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 02:07:46, 68224 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_00E8&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&12
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 03:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:42, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 03:56:42, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_02501462&REV_A1\3&13C0B0C5&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:36, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_02501462&REV_A1\3&13C0B0C5&0&10
Name: NVIDIA nForce3 250 Parallel ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_00E5&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&40
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_00E4&SUBSYS_02501462&REV_A1\3&13C0B0C5&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_00E3&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&50
Name: NVIDIA nForce3 250 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_00E2&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&58
Driver: C:\WINDOWS\system32\DRIVERS\nv_agp.SYS, 4.12.0001.0377 (English), 10/29/2003 13:02:00, 21120 bytes
Driver: C:\WINDOWS\system32\NVCOG.DLL, 1.00.0000.0015 (English), 3/25/2004 15:29:00, 32256 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_00E1&SUBSYS_00000000&REV_A1\3&13C0B0C5&0&00
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_00E0&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 3/31/2003 08:00:00, 35840 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_00DF&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&28
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.0442 (English), 5/17/2004 14:00:54, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.0442 (English), 5/17/2004 14:00:42, 56960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.0442 (English), 5/17/2004 14:00:34, 191232 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 5/17/2004 13:48:58, 8192 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0015 (English), 5/10/2004 08:53:16, 32256 bytes
Name: NVIDIA GeForce 6800 Ultra
Device ID: PCI\VEN_10DE&DEV_0040&SUBSYS_00000000&REV_A1\4&1AD7642&0&0058
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9147 (English), 8/11/2006 21:42:42, 3958496 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9147 (English), 8/11/2006 21:42:52, 4496128 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9147 (English), 8/11/2006 21:42:50, 155715 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9147 (), 8/11/2006 21:45:20, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9147 (), 8/11/2006 21:43:10, 196608 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9147 (English), 8/11/2006 21:42:58, 5636096 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9147 (English), 8/11/2006 21:43:02, 7630848 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9147 (English), 8/11/2006 21:43:04, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9147 (English), 8/11/2006 21:43:08, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11048 (English), 8/11/2006 21:43:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:22, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:28, 5611520 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:30, 5251072 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:32, 3039232 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:34, 2928640 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:38, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:40, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:42, 888832 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:42, 2859008 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:44, 2904064 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:46, 2953216 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:36, 1236992 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0010.9147 (English), 8/11/2006 21:45:38, 1732608 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 8/11/2006 21:43:06, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 8/11/2006 21:43:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 8/11/2006 21:42:44, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 8/11/2006 21:42:44, 35840 bytes
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 3/31/2003 08:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 3/31/2003 08:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 3/31/2003 08:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 3/31/2003 08:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 02:08:21 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 82432 bytes
system.dll: 1.01.4322.0573 English Final Retail 8/30/2006 02:21:20 1216512 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 8/30/2006 22:47:51 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 8/30/2006 22:47:51 567296 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 8/30/2006 22:47:51 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 8/30/2006 22:47:51 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 8/30/2006 22:47:51 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 8/30/2006 22:47:51 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 8/30/2006 22:47:51 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 8/30/2006 22:47:51 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 8/30/2006 22:47:51 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 3/31/2003 08:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 03:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 03:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 03:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:24 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 23:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 03:56:45 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 03:56:57 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 03:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 03:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 03:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 03:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 03:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 03:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 03:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:15:21 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 01:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:41 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:38 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:12 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:57 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:44 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:57 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:57 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:12 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:12 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:12 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 03:56:43 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:16 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:28 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:16 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:57 90624 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:10:21 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 03:56:46 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:09:58 51328 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x0009c400,1,1,,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00030d40,1,1,,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB Audigy 2 ZS Audio [9000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS MIDI IO [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Sw Synth [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Synth A [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Synth B [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
SB Audigy 2 ZS MIDI IO [9000],0x00200000,2,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [9000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy 2 ZS DirectMusic Synthesizer [9000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Sw Synth [9000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth A [9000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth B [9000],0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SB Audigy 2 ZS Audio [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB Audigy 2 ZS Audio [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
SB Audigy 2 ZS Synth A [9000],0x00200000,11,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [9000],0x00200000,13,2,,5.03.2600.2180
PSU = Coolmax Active PFC, its a beast with strong rails,
http://www.coolmaxusa.com/productDe...ls=features&subcategory=120mm&category=single
No i'm not running it overclocked, that's why i can't figure out why the bios is giving me that message. I'm don't have any temp sensors hooked up but this thing has more fans than michael jackson.
I'm thinking of just low leveling the drives and starting over? If this helps any, the old PC had Win on one drive and Linux on the other, i just did a quick format...
quick format= no no
do a full format and see if problems still happens
Correct me if i'm wrong, but the full format is same as quick with the addition of checkdisk or what not? Should i go as far as writing 0's to the drive? Welp, being that i'm out of options, let me try what you reccomend.
yea quick format doesnt have the checkdisk to scan for bad sectors, thats why full format takes awhile
SOLVED?!
Hehe...
My PSU is now Antech :eek:
Yes, the last one blew, BUT i think i solved the problem! While replacing the beast i noticed there were 2 power connections on the VGA card. There was only one connected when i got the machine so i didn't think twice. I didn't get any errors though. This time around when i booted up into windows (new supply, 1 connection to vid) i got an alert from Nvidia panel. I connected a separate lead to the secondary and bingo! I was able to play BF 2 without any glitches at all.. played for 30+ min with no issues. Boy this is a nice move from an Athlon 2200+ with 512k! I suppose i know why the dang PSU failed now... Glad he threw in an extra PSU and Mobo!
