A friend gave me a water cooling setup that consists of a radiator with 2 120mm fans, water block and pump/reservoir. I picked up some cheap vinyl tubing from Home Depot and some strong spring clamps. I currently have distilled water and a little CLR running through to clean and check for leaks. IT IS NOT INSTALLED IN PC YET. Has anyone else used these primitive supplies? I have a bottle of Ice Dragon ready to go in. Not sure if I should order some new connections/tubing or run it as is.
So far no leaks with the clamps on. I think I need some tubing that is a little softer though.
