That is for the reference board, yours may be different so confirm that the chip numbers are the same.
Also bear in mind that increasing the VDDR voltage too much would result in the bus voltage going way ouy of spec as VDDQ and VDDR are supplied by one controller. A more extreme mod involves removing the VDDQ bridges and soldering a diode in there, but that definitely ain't for the faint hearted
Also be sure to have damn good cooling before you start to Vmod.
