- May 30, 2004
Idk, maybe I should just have it looked at. Nothing seems to be working.
Nah, it's just time to do some methodical troubleshooting. You have a nice fresh O/S install, so pull all of your components, and replace the minimum needed to POST. 1 stick of ram, cpu, 1 gfx card, and an optical drive. You can use a live cd of some kind of Linux to give your system a workout. If it works ok with that, add your hd, and see how you run. Make sure all drivers are up to date, including the chipset, and run with that awhile. If all goes well add another component... and so on.
I'd take a close look at the psu. I'm assuming you've tested the ram thoroughly, so the psu would be next in line, and easy to check. It can also cause some mystery problems that are hard to track down, and not really obvious.
