- Aug 5, 2002
You NEVER disable windows swap. Windows needs it weather you have 512Meg or 16Gig of ram Windows and some programs REQUIRE the use of virtual memory.
If the HDD is making noise its because the indexing service is still activated in the background. So I'd suggest you to disable this, as well as windows defender at least from times your typically on the PC and move it to a night time hour or so.
As well you won't see much benefit in 64-bit version of Vista. While yes your CPU is 64-bit compliant, you don't have the memory to really utilize it. The OS takes about 200-400Megs more over the course its turned on than 32-bit mode that I've seen. As well doubt you'd use more than 2gigs on a program expeically only having 2 gigs of memory since it would run really slow.
I'd suggest if you decide to do another format in the future use 32-bit edition unless you only have the 64-bit OEM edition, then well guess your stuck with it. Now don't that this wrong but while the OS might seem to be eating half of your memory, really it isn't. Superfetch has programs loaded in the background ready for use that you typically use so it has nice quick opening times on it, but when needed SF will dump what it has in memory thats not being used to make room for the main programs in use. At least that is its intended purpose.
