Yes, but the timings will probably need to be manually adjusted in bios. Have you done that before? We'll cross that bridge . . .
I think at this point you need to start doing 2 hour Prime95 stress tests. 20 minutes is economical time wise at the front end of the overclock process but its not enough to confirm stability.
If necessary to get your memory where you want it, you can down clock the CPU multiplier if the CPU starts to become unstable. You've only got a little bit to go to get to 666/1333 however.
