- Sep 30, 2005
jonspd said:Get some conductive paint or pen from a defogger repair kit @ a auto store.
VDDIM has to be mesured with a MM unless you want to do OCH winbond chip modding.
you ram timing are incorrect. that would cause it.JWilson said:I did the R3107 Vdimm mod to get 2.9V, but when doing Memtest or Prime95 the measured Vdimm is jumping all over the place! My meter is jumping between 2.68V and 2.8V. I doubt if that is going to add any stability for overclocking. Anyone else measure Vdimm after doing the Mod and running memory intensive programs?
Not recommended. could short the dimm slots.RAA said:I know that, that's how I measured vdimm pre doing 3.2v mod..
But now that area is covered by a wire and solder and I don't know of any way to see what my RAM is getting other than Winbond mod but I only want to measure it once for verification.
Sure I heard someone saying they took measurement from a dimm.
OC'd to 240x11 using 1.54v not bad. 2.64ghz still 29'c idle
