Hi,
I own an X79 rig, specifically my motherboard is Asus P9X79LE, my CPU is a 4930k @ 4.4GHz with voltage set at 1.36V, RAM is TridentX 2400MHz CL10 @ 1.65V, and VCCSA and VTT are both at 1.1V. system is running good and stable. However I want to push it even further, specifically 4.5 or 4.6GHz on my CPU. I have a Corsair h80i which is a so-so cooler, temps on prime95 highest at about 75c after a few hours. 4.5GHz and 4.6GHz can both boot, but voltage crosses 1.4V (I think something like 1.45V boots with 4.6GHz). Problem is I cannot get neither 4.5GHz nor 4.6GHz to be Prime95 stable, they can pass cinebench or intel burn test, I think RealBench as well, but Prime95 never. So I'm starting to wonder, maybe sustained heat is the problem, and specifically maybe on the VRMs. Is it worth it to place a fan specifially at the top heatsink of the motherboard? If so, which size and what direction (directly on it, to the size, below it, etc)
Wanna hear recommendations! If you think I'm chasing ghosts here don't hesitate to tell me! I love learning stuff here!
