- Jul 14, 2003
So my recent foray into reconfiguring an HP Z400 workstation setup into a gaming desktop proved successful. I pitched this idea to a friend of mine who i build a system for a long time ago. His current system is an Athlon64 x2 5200+ build with i think 4gb of DDR2 and he currently has a Nvidia 450gts GPU. I imagine his system is at a dead end as far as trying to keep current, so lets up the game.
Athlon64 x2 5200+ passmark link http://www.cpubenchmark.net/cpu.php?cpu=AMD+Athlon+64+X2+Dual+Core+5200+
I first looked at ebay to possibly replicate my z400 results and came across this: http://www.ebay.com/itm/282067206824?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Z400 workstation mobo with 12gb RAM, cooler, and Xeon w3550 (i7-950 equivalent) for $120 (but no real warranty). Seems like a good idea especially considering that it can be upgraded to a hexacore that scores as good as an i7-3770 later on, but it isnt the most current regarding features and i let him know this. So i set out to configure something else that would be affordable for similar performance and i came up with a socket FM2+ build with the excavator Athlon x4 845 and 16gb ram for about $50 more than the ebay deal. Current features like PCI-E 3.0 and USB 3.0 (though i guess PCI-E 3.0 x8 is the same a PCI-E 2.0 x16), but is new and has warranty and he can do payments thru Newegg. Downside to this setup is it seems after this 845, the socket is dead with no upgrade path as far as i can tell. Not really digging going with a Pentium dual core, and im not crazy about i3s either, though i3 might be considered if we can keep mobo/CPU/RAM under $200 as it presents a future upgrade path that the FM2+ setup wouldn't offer. My friend doesn't want a "temporary fix" type of setup, but wants his stuff to last a while.
edit -just did a quick i3-4170 + mobo + 8gb ram config on newegg. $185. I'll let my buddy know about this as an option-
What do you all think? Thanks
