- Jan 5, 2005
- Ormond Beach, FL.
http://www.performance-pcs.com/cata...oduct_info&cPath=59_318_659&products_id=38770
I bought two with four MCP35X pumps. With the pumps installed, they will not spin or pump. It's like the impeller is too tall for the res and is being stopped against the res. This happened with both res's and all four pumps.
I connected all four pumps uninstalled and turned them on (just for a second) and they spin fine.
It must not be compatible with MCP35X pumps because if you buy it with pumps, it comes with 3.2 versions. Nowhere does it say you can't use MCP35X. It says they "recommend" 3.2 pumps for PWM, but MCP35X has PWM too. It says made for DDC pumps.
